Local Time 05:38 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 : SERIAL COM PORT
SillyCony
Posted: 01:26pm 14 Jan 2021
Hi all,
For a current project I need to send a series of 'arbitrary' bytes across a serial link. This series of bytes should not be formatted. It must therefore not contain the "CR / LF" sequence at the end of transmission.
However, I only found the PRINT function in the Basic of the CMM2 to send series of bytes necessarily in the form of STRING, therefore with the sequence "CR / LF" at the end. I couldn't find a WRITE (* Buffer, AmountOfData) function for example.
Do you know a solution to fix this problem?
I am using com port number 2, and the firware Ver 5.05.05
Best...
Eric
Posted: 01:37pm 14 Jan 2021
Ending a PRINT statement with a semi-colon ; suppresses the CRLF, e.g.
PRINT "foo" ;
Sends "foo" without CRLF.
Hope that helps,
SillyCony
Posted: 02:09pm 14 Jan 2021
Hi Thwill,
Thanks a lot. It works.
Thoroughly on the subject, we sometimes forget the simplest solutions !!!
Eric
