Local Time 05:37 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Saving and recalling variables from SD card
frnno967
Posted: 03:07am 12 Jan 2021
sub saveconfig
open "settings.cfg" for output as #7
print #7, comporttype$
print #7, rs232%
print #7, linefeedstate$
print #7, linefeeds%
print #7, modeminitstring$
close #7
end sub
sub loadconfig
open "settings.cfg" for input as #7
line input #7, comporttype$
line input #7, rs232%
line input #7, linefeedstate$
line input #7, linefeeds%
line input #7, modeminitstring$
close #7
end sub
When I use the above subroutines in my code, I find that the variables are not read back from the SD card correctly. It seems like it can't save or recall the INT variables correctly. Is this correct behavior, or a bug?
Thank you.
Jay Crutti: Ham Radio Operator, K5JCJ. Computer Enthusiast. Musician. Engineer.
Turbo46
Posted: 05:10am 12 Jan 2021
As the manual says:
  Quote  LINE INPUT #nbr, string-variable$
Reads an entire line from the console input into 'string-variable$'.
'prompt$' is a string constant (not a variable or expression) and if specified
it will be printed first
LINE INPUT is expecting a string. Try:
INPUT #7, rs232%
Or if you do want to use LINE INPUT try:
LINE INPUT #7, a$ : rs232% = VAL(a$)
Edited 2021-01-12 16:33 by Turbo46
Posted: 06:46am 12 Jan 2021
Agreed.  The problem is your rs232% which is an integer, and you can't line-input an integer, only strings.
As well as above, you could change the 2nd line in your code examples to:
Print #7,STR$(rs232%) to save, and...
Line Input #7, A$:rs232%=VAL(A$) as Bill posted above to read it back.
EDIT: You will need to do the same for your linefeeds% integers too.
Edited 2021-01-12 16:48 by Grogster
Posted: 07:51am 12 Jan 2021
+1, except
may as wwell be
Print #7,rs232%
i.e. as it is already.
Posted: 08:19am 12 Jan 2021
  Quote  It seems like it can't save or recall the INT variables correctly. Is this correct behavior, or a bug?
What version of MMBasic? Look at BIN2STR$ and STR2BIN that were specifically designed for this purpose
