Local Time 05:37 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM.INFO$(CPUSPEED) returns not a string
jirsoft
Posted: 04:54pm 09 Jan 2021
I just found out, that MM.INFO$(CPUSPEED) returns not a string but integer number. So either should be that changed in doc (easiest) or in FW...
MM.INFO$(CPUSPEED)
      Returns the CPU speed as a string. This will be 400000000 for the Y
      version of the STM32H743II or 480000000 for the V version.
Jiri
