Local Time 05:35 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : W10: Help setting up Wireshark....
Posted: 05:19am 09 Jan 2021
Hello all.
I need some help please.  I am trying to setup Wireshark so that it will monitor a specific IP address, but I am a little lost, as the program is quite complex.
Can anyone help me?
I want it to monitor IP address 13.107.4.32, which is the Microsoft NCSI server.
I have the globe-icon in the system tray issue, where W10 insists there is no internet, even though there is, and it was suggested on the MS forum thread by a MS employee that packet capture should be used to help determine what the issue is.
The thread on the MS forums is now 21 pages long and 625 posts, so I don't think this issue is going to be fixed anytime soon.  It appears to be specific to Windoze Ten, as other versions of Windoze don't have this issue, and Linux definitely never moans about no internet when there actually is.
So, I want to setup an IP packet capture for the above IP address, capturing both outgoing and any incoming replies from that IP address.  I have worked out how you setup a capture file, but the packet filtering and display filtering is where I am lost.
Can anyone help?
Posted: 05:56am 09 Jan 2021
Try
ip.dst == 13.107.4.32 || ip.src == 13.107.4.32
That should capture any thing to or from the IP in question.
I normally capture all and use a filter similar to that in the display area but it should work in the capture field as well.
No.
It needs to be
host 13.107.4.32
in the capture filter (just to be different).
Edited 2021-01-09 16:05 by TassyJim
Posted: 07:47am 09 Jan 2021
Thanks, Jim.
I will try to put that in motion, and report back here.
