Local Time 08:00 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to extend  Comms  between 2 computers
jeffj
Posted: 03:12am 27 Dec 2020
I run my hydroponics on my trusty maximite in my garage
The garage is just on the limit re distance approx 60 m Sometimes it will communicate on remote computer from dell laptop on Win 10 to an XP laptop which is connected to the maximite.
Any advice on how to improve the Comms would be appreciated.
Jaycar sells a booster but I am not sure how far that will transmit
I would also like some advice how I can wake up the XP remotely I have tried several solutions that don't work
Thanks Jeff
Tinine
Posted: 03:26am 27 Dec 2020
I have been using these devices for 8 years
Posted: 12:55pm 27 Dec 2020
If you're talking wifi, I have used the TP-Link AC750 WiFi Range Extender - Dual Band 5G (but there are many choices).
jeffj
Posted: 05:29am 29 Dec 2020
Thanks Tinine and Lizby
Yes wifi is the problem I did have  a booster installed .There are 3 leds on the booster which I assume indicates signal strength. there is only one on - with the booster  right up alongside the modem
I have just received a new Telstra Smart  modem which I have installed and all other equipment  is working ok.
The range must be better as communications to the shed via the new modem  is slow but acceptable.Comms via the Wi Fi booster is not good at all The booster is recognised but that is about all.
I have come to the conclusion that the booster is faulty.The information supplied with it is very poor 10 pages on a booklet 50 X 40 and no info on the net. I will get a new one and see how that goes.
Jeff
Posted: 06:43pm 29 Dec 2020
Not sure what your communication is, but if it is serial, at low baudrate (9600), you may be able to use an HC12 link. That will work on 60 meters without problems.
As for WIFI boosters I have had one that worked fine for few days, and then died. After investigation it prooved that the ground tab (heat transfer) of the amplifier chip was not soldered. The chip overheated, and died.
Edited 2020-12-30 04:46 by Volhout
