Local Time 08:00 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Firmware update verify failed
bar1010
Posted: 04:27am 22 Dec 2020
Has anyone had the verify process fail when updating the firmware for CMM2?
Now I do not receive a video signal.  Tried a different VGA to VGA cable, but
Still no signal.  The power light comes on on the Color Maximite 2 though.
Was using the second method from the back of the user manual.  The download
Part completed, but then the verify part failed.  Was attempting to update to
5.06.00.
Edited 2020-12-22 14:29 by bar1010
Posted: 05:09am 22 Dec 2020
Set the BOOT CONFIG switch to "SYSTEM" and try again.
The bootloader will be safe so no disaster.
Using serial instead of USB A-A cable is very slow so there is time for problems.
A USB A-A cable is (very much) the better way to go.
Turbo46
Posted: 05:33am 22 Dec 2020
I had it fail when I tried the slow method. It claimed to have lost the USB connection. I had to do as Jim suggested because the software could not recognise the CMM2.
  Quote  A USB A-A cable is (very much) the better way to go.
bar1010
Posted: 05:32pm 22 Dec 2020
  TassyJim said  Set the BOOT CONFIG switch to "SYSTEM" and try again.
That fixed the issue.  Now have firmware 5.06.00 on the Color Maximite 2!
Thanks for the help regarding this issue.
Edited 2020-12-23 03:33 by bar1010
