Forum Index : Microcontroller and PC projects : drawing a Circular gauge
| envirotronics Newbie Joined: 18/02/2016 Location: AustraliaPosts: 23 |
Can anyone provide a couple of lines of code to draw the GUI GAGE. I just cannot get it to work. Also, when the line of code is longer than the LCD do we just ignore the message :line of code too long" and keep coding? |
Don't know what platform you are using but look at Geoff's Projects-Micromite Backpack. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
This draws two gages. The first is single colour while the second has green/yellow/red for increasing temperatures. font 4, 1 GUI gauge #1, 150, 110, 100, RGB(white), 0, 0, 1000, 0, "l/h", RGB(cyan) CtrlVal(#1) = 612 GUI gauge #2,150,310,100,RGB(white),0,0,100,1,"`C",RGB(green),50,RGB(yellow),75,RGB(red) CtrlVal(#2) = 80 No. Instead you can break the line in sections to edit it - then later reassembled it by deleting the line breaks. This is tedious but there is a limit to what an editor embedded in a microcontroller can do. Geoff Edited 2020-12-21 18:30 by Geoffg Geoff Graham - http://geoffg.net |
Thank you Geoff for your respectful and mentoring style assistance. |
