Local Time 08:00 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sprite questions
electricat
Posted: 03:23pm 18 Dec 2020
There i wrote few simple lines of code:
box 0,0,50,50,4,rgb(red),rgb(white)
sprite read 1,0,0,50,50
a=0
b=0
d=12
do
if keydown(1) =129 and a<550 then a=a+1 : sprite show 1,b,a,0:pause d
if keydown(1) =128 and a>0 then a=a-1 : sprite show 1,b,a,0:pause d
if keydown(1) =130 and b>0 then b=b-1 : sprite show 1,b,a,0:pause d
if keydown(1) =131 and b<750 then b=b+1 : sprite show 1,b,a,0:pause d
loop
While moving up and down sprite i see black horizontal stripes on sprite. While moving left-right black line appears like "standing black strip" And if I realase keys, strips goes away, so it is synchro problem/timing ? (It`s PHILIPS 190S LCD monitor and board CPU runs at 480Mhz )
What I am doing incorrectly?
Is it ok only with static things, but with any animations I should route all changes  through PAGE COPY ? Or I am doing it somehow totally wrong way?
I am reading through forum/manuals etc., I`m really sorry if such question was already discussed, used to use forum search but maybe choosed wrong keywords.
My MMBasic 'sand box'
Posted: 03:29pm 18 Dec 2020
  Quote   but with any animations I should route all changes  through PAGE COPY ?
Yes, either that or use getscanline to synchronise
Edited 2020-12-19 01:29 by matherp
electricat
Posted: 09:17pm 18 Dec 2020
Thank you for your precious time matherp!
This time I went optimal way and now it works nicely
Ha ha its almost Ms. Pacman now :D
a=0
b=0
d=1
do
sync=getscanline
if sync < a+150 and sync > a-150 then goto rep
if keydown(1) =129 and a<550  then a=a+1 : sprite show 1,b,a,0 :pause d
if keydown(1) =128 and a>0    then a=a-1 : sprite show 1,b,a,0 :pause d
if keydown(1) =130 and b>0   then b=b-1 : sprite show 1,b,a,0 :pause d
if keydown(1) =131 and b<750   then b=b+1 : sprite show 1,b,a,0 :pause d
rep:
loop
do
Edited 2020-12-19 07:18 by electricat
electricat
Posted: 12:51pm 22 Dec 2020
Matherp,
What could cause not clear picture in video I attached below ?
Soon after I played with GETSCANLINE I used to test also PAGE COPY , but noticed something like pixel noise, like scanlines blinking, I dont know how to name it exactly, but screen was not clear as could/should be.
So I tested example from "Graphics Programming on the Colour Maximite 2" but noticed the same "noise" effects please see video I attached.
Might it be my hardware or maximite`s firmware problem?
My fw version is 5.05.05
https://youtu.be/q5qoCdZ-W5I
Posted: 01:03pm 22 Dec 2020
Assuming you have a Waveshare based system you need to install the optional crystal oscillator
electricat
Posted: 02:27pm 22 Dec 2020
OK. I`ll try that.
