Forum Index : Microcontroller and PC projects : Micro Colour Maximite
I wonder if there is a niche for a stripped down CMM2 ? No Numchuck,small as possible form factor and use a 7inch VGA tft? I realise there is the H743 Armmite but the extra power, memory and functionality of the CMM2 might have a unique spot? Something perhaps Peter may care to comment on - could the H743 Armmite ever utilise extra external RAM but retain the ability to drive all the TFT displays and include some/much of the CMM2 functionality? Essentially, a super dooper micromite? Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
| Nimue Guru Joined: 06/08/2020 Location: United KingdomPosts: 450 |
That sounds interesting. Nim Entropy is not what it used to be |
bigmik![]() Guru Joined: 20/06/2011 Location: AustraliaPosts: 2983 |
Doug, My Only comment to that is that the standard PCB will fit nicely behind a 7" TFT so why not just modify slightly to suit your planned build? Kind Regards Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
