Local Time 19:22 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Graphics Programming Manual - update for MMB5.06.00
panky
Posted: 11:48pm 16 Dec 2020
Hi all,
I have updated the Graphics Programming Manual to include the new features that are include in version 5.06.00 of MMBasic.
I have not yet covered the 3D engine and DRAW3D commands or the extensive range of MATH commands. These almost require a manual of their own but I may try to at least introduce them in a later update.
I have added a chapter covering the Great Octahedron Challenge as a teaser showing the fabulous graphics capabilities of the CMM2.
As always, I welcome comments or advice on errors for me to fix.
Doug.
Graphics Programming on the CMM2-v3d.pdf
Turbo46
Posted: 12:28am 17 Dec 2020
Thanks Doug,
We do appreciate the work you have put into it. Glad to see your name is on it too.
LeoNicolas
Posted: 05:26am 17 Dec 2020
Amazing job Doug
This manual is super useful.
Did you see the updated code for the quaternion examples?
https://www.thebackshed.com/forum/ViewTopic.php?TID=12738&PID=159705#159705
Edited 2020-12-17 15:27 by LeoNicolas
panky
Posted: 09:08am 17 Dec 2020
Leo,
Thanks for that link. As I get my head around all the powerfull 3D stuff you and your two countrymen do using Peter's mind boggling graphics programming functionality, I plan to attempt a separate, in-depth treatise in the 3D capabilities of the CMM2.
This is a major task for me as my math finished at year 11 high school. Even with a lifetime in electronics and computer maintenance, you and your compatriot's level of knowledge is well beyond me.
Thanks again for your previous support,
Doug.
Edited 2020-12-17 19:13 by panky
CircuitGizmos
Posted: 03:37pm 17 Dec 2020
I've forgotten more math than you ever knew. I think I've now regressed to only knowing add, subtract, multiply, and that other one.
LeoNicolas
Posted: 02:45pm 18 Dec 2020
The updated exemple code is using the firmware quaternion functions instead the custom quaternion functions and that complex math. The code is less complex and more clear
Posted: 09:18pm 18 Dec 2020
Thanks Panky. I have updated the CMM2 firmware zip file.
ChrisJournoud
Posted: 01:30pm 21 Dec 2020
My nearly 2 cents
Reading the doc, I have seen that in v.5.06.00, the "OPTION DEFAULT MODE n" can now be fixed at 1, 8, 9, 10, 11 or 12. It is still said 1, 8 or 9 in the doc
panky
Posted: 10:11pm 21 Dec 2020
Thanks Chris,
well spotted - will update in next release.
Doug.
panky
Posted: 01:47am 05 Apr 2021
Some patches and typo fixes. This release, v3f, should cover all the features available in the stable 5.06.00 release of MMBasic.
I will hold off on any more updates until 5.07 is released (lots and LOTS of new stuff there to get my head around and document     ).
Graphics Programming on the CMM2-v3f.pdf
Doug.
