Local Time 09:04 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picromite V5.05.05
Posted: 09:56am 14 Dec 2020
I decided to give the Picromite code one last try and have built a version that "runs" on Pi-ZeroW, Pi3, and Pi4 using the latest Pi-OS version
In all cases I have used the latest Raspberry Pi Imager to create the SD card on my PC.
I then used rasp-config to enable SSH
Then I used apt-get to both update and upgrade the image
Finally I used apt-get to install pigpio
The Pi-zero was running Pi-OS Lite, the others the full desktop image
The new MMbasic build runs up successfully on all versions and I have run simple programs but haven't tested the I/O in any rigorous way
It is interesting to note that with the overhead of Linux even the Pi4 is slower than the CMM2
The build is up-to-date with Geoff's latest MMbasic releases
As always you need to enable execution of mmbasic (chmod + x mmbasic)
and run it with sudo (sudo ./mmbasic)
mmbasic.zip
Nimue
Posted: 10:31am 14 Dec 2020
@matherp  - forgive what might be a trivial question.... does this mean that potentially I can run MMBASIC on that new fangled Pi400 Keyboard mashup thing??
Nim
Posted: 01:01pm 14 Dec 2020
Downloaded, installed, and (minimally) tested on a pi-0-w. Thanks very much.
lew247
Posted: 01:15pm 14 Dec 2020
Peter thank you for that but I'm getting
[LIBRARY] Sub testsub
Error : Duplicate name
with any program that goes to a subroutine
EDIT:
It did this one ok
cls
do
for a = 1 to 10
decode
pause 100
next a
loop
SUB decode
print "test print"
END SUB
Edited 2020-12-14 23:21 by lew247
lew247
Posted: 01:22pm 14 Dec 2020
This one it errors on
> run "zz"
[LIBRARY] Sub DECODE
Option EXPLICIT
Dim ss$,sec1$,aa$,a1$,a2$,a43$,a50$,b$,c%, sec, tag$, i%
Dim  a$(60)
On error skip
UDP close
UDP server 4997
On error skip
UDP receive aa$,b$,c%
If c%>0 Then DECODE
UDP close
Sub DECODE
tag$=Mid$(aa$,1,2)
Select Case tag$
 Case "#1": For i%=1 To 25: a$(i%)=Field$(aa$,i%+1): Next i% ' LISTFIELDS
 Case "#2": For i%=1 To 25: a$(i%+25)=Field$(aa$,i%+1): Next i%
   For i%=1 To 50: Print i%;" ";a$(i%): Next i%
End Select
print a$(1)
print a$(50)
btw
Thank you so much for coming back to Pi-Cromite
If we get one working version I don't care if I never have to update the PI OS, as long as MM works :)
Edited 2020-12-14 23:24 by lew247
ceptimus
Posted: 02:25pm 14 Dec 2020
Maybe someone should produce some image files from a pre-configured SD card of the smallest capacity that will hold the system (8 GB ?) and then we can just use Balena Etcher or similar to create ready-to-go Picromite SD cards for our Pis - and we won't need to worry about future updates to the O.S. requiring new install files.  Of course, when the O.S. is upgraded and someone tests that Picromite still works (or modifies it to work) then fresh image files could be created.
If anyone does this, I suggest using a wired Ethernet connection for the Pi you're creating the images from - that way, there will be no WiFi access point or password information encoded in the image files, and the pi password could be left at its default value.  People can always use raspi-config or similar to set up WiFi and passwords later.
A possible problem might be that the Raspbian licence or Micromite licence doesn't allow such a method of distribution?
Assuming it can be done without breaking the licence conditions, we would still need to consider where to host the image files, and how much server bandwidth they might take.
Rado
Posted: 02:44pm 14 Dec 2020
I would strongly discourage using operating system that is "frozen in time", unless it is in no way connected to the Internet. The risk of someone exploiting some security flaw that has been found but not patched is increasing with time that OS (or parts of it) has noot ben updated. This would be fine if you have a standalone machine that does not talk to other things on Internet, or is confined to an otherwise isolated network.
On the other hand, I don't see the reason why updating the OS or any of its components would break MMBASIC, for as long as there are no big changes in kernel or system libraries (does not happen that frequently)??
Posted: 02:59pm 14 Dec 2020
Sorry - failed
The latest Pi-OS seems to have completely broken MMbasic's memory management which is why lew247 is seeing the issues.
I'm afraid MMbasic on the Pi is back to being dead - this time finally and forever
lew247
Posted: 03:23pm 14 Dec 2020
  matherp said  Sorry - failed
aww
thanks for trying Peter
Edited 2020-12-15 01:24 by lew247
chris
Posted: 08:59pm 14 Dec 2020
I'm sure you've checked it out, but what are the downsides of the Circle baremetal library for Pi?
https://github.com/rsta2/circle
Edited 2020-12-15 07:00 by chris
Posted: 10:55pm 14 Dec 2020
It's C++ ?
Plasmamac
Posted: 01:36am 15 Dec 2020
It is interesting to note that with the overhead of Linux even the Pi4 is slower than the CMM2!
Wow i cant believe this..
Plasma
Posted: 07:13am 15 Dec 2020
  Plasmamac said  It is interesting to note that with the overhead of Linux even the Pi4 is slower than the CMM2!
Which test(s) show that?
