Local Time 09:04 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RC6 PRINT Problem?
toml_12953
Posted: 04:15pm 13 Dec 2020
The following (it worked in RC5):
PRINT "FAULTY SPEEDOMETER SPOTTER!!"
PRINT
PRINT "SECONDS",@(120);"MILES PER HOUR"
PRINT "*******",@(120);"***** *** ****"
should print
SECONDS       MILES PER HOUR
Instead it prints
              MILES PER HOUR
SECONDS
Edited 2020-12-14 02:22 by toml_12953
Posted: 04:20pm 13 Dec 2020
Works for me as expected - try downloading and flashing again
toml_12953
Posted: 04:24pm 13 Dec 2020
  matherp said  Works for me as expected - try downloading and flashing again
Have you tried over the serial connection instead of to the screen? That's what I was running at the time.
Posted: 04:27pm 13 Dec 2020
I always run over the serial connection so I tend to miss screen issues rather than the other way round
toml_12953
Posted: 07:53pm 13 Dec 2020
  matherp said  I always run over the serial connection so I tend to miss screen issues rather than the other way round
What terminal emulator are you using? I tried TeraTerm and PuTTY on Windows.
Is it possible they don't respond to control codes properly?
I'll try to re-download anywway. If it works, then the verification function on the programmer doesn't work too good!
toml_12953
Posted: 08:04pm 13 Dec 2020
I have to mention that it does work in direct connection mode rather than serial.
I just downloaded it again and reflashed. Now I get a different result over serial!
After a screen clear, I get this:
              MILES PER HOUR
But if I run again without clearing the screen, it runs normally and prints
I can run over and over without clearing the screen and the output is OK. The first run after a CLS always has the SECONDS missing.
Edited 2020-12-14 06:18 by toml_12953
Posted: 08:47pm 13 Dec 2020
Peter wants you to download the ZIP file again, not just re-flash. There was a problem with the first one he uploaded.
I can't see any problems with the latest firmware.
toml_12953
Posted: 09:12pm 13 Dec 2020
Yes, That's what I mean by re-download. I call sending the file to the computer flashing.
I have redownloaded the ZIP and re-flashed the firmware. Both TeraTerm and PuTTY have a problem when I first do a CLS. When they reach the bottom of the screen they don't show all the output either. Here's the whole program I was using:
10 PRINT "FAULTY SPEEDOMETER SPOTTER"
20 PRINT
30 PRINT "SECONDS",@(120);"MILES PER HOUR"
40 PRINT "*******",@(120);"***** *** ****"
50 PRINT
60 FOR T=70 TO 40 STEP -1
70   LET F=T/3600
80   LET R=1/F
90   PRINT T,@(120);R
100 NEXT T
110 END
When I first run it the word SECONDS is missing. After that, SECONDS shows up but some output is missing if the whole table would extend past the bottom of the terminal window.
P.S. Please look past the program itself. It's just an example to show corrupted output in terminal programs.
Edited 2020-12-14 07:15 by toml_12953
Posted: 09:40pm 13 Dec 2020
When you use PRINT @(x), MMBasic translates the position into VT Escape codes such as <esc>[23;15f
The pixel position converts to character positions.
Normally, you would include the 'y' position as well.
MMBasic uses the current line and the y value if not provided.
In the example code you provided, the first few lines print without any location information and the first time you use location is before the "MILES"
IT is this mix of position printing and plain printing that confuses the terminal programs.
If you want your program to display correctly on terminals, it is safer to use full positioning (x,y) and for the whole display page, not just part of it.
It is also safer to start you program with a CLS.
MMBasic is sending the same information, but with CLS, the line number will be different compared with not doing a cls.
toml_12953
Posted: 10:15pm 13 Dec 2020
  TassyJim said  When you use PRINT @(x), MMBasic translates the position into VT Escape codes such as <esc>[23;15f
Thanks for your clear explanation! I don't use the serial interface very often but wanted to report a bug if it was one. Now I see it's not.
