Local Time 10:04 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sorry for the stupid math question
RCMAN
Posted: 03:27pm 10 Dec 2020
If I have a float value how do I get the value and remainder separately?
RC
twofingers
Posted: 03:34pm 10 Dec 2020
Hi RC,
try FIX(number)
Michael
Posted: 03:36pm 10 Dec 2020
x= 3.141
y=Int(x)' integer part
z=x-y ' fractional part
RCMAN
Posted: 04:01pm 10 Dec 2020
  CaptainBoing said  x= 3.141
Thank you for both your answers.
RC
RCMAN
Posted: 04:49pm 10 Dec 2020
RC
Working Perfect!
Edited 2020-12-11 02:50 by RCMAN
Bizzie
Posted: 08:18pm 10 Dec 2020
Why not use MOD?
eg mod(3.141,1) = .141
Rob White
Nimue
Posted: 08:22pm 10 Dec 2020
I wonder which way is less computationally complex:
Int(x) and Mod(x,1)   OR
Int(x) and calculate (x-int)
Any other ways?
Nim
Nimue
Posted: 08:24pm 10 Dec 2020
  Nimue said  I wonder which way is less computationally complex:
Any other ways?
Nim
I rejected making into a string and splitting up and then making back into numbers.
toml_12953
Posted: 08:26pm 10 Dec 2020
Any other ways?
Nim
I don't know about MMBASIC but I do know that in some BASICs, the subtraction method sometimes has a rounding error. In ANSI/ISO BASIC, there's an FP() function to get the fractional part that eliminates errors.
toml_12953
Posted: 08:27pm 10 Dec 2020
  Bizzie said  Why not use MOD?
Clever!
twofingers
Posted: 08:37pm 10 Dec 2020
  Nimue said  I rejected making into a string and splitting up and then making back into numbers.
I don't!
>Print field§("3.14159",1,".")
3
>Print field§("3.14159",2,".")
14159
not soo bad!
Posted: 08:44pm 10 Dec 2020
  Quote  mod(3.141,1)
Have you tried?
The format for MOD would be 3.141 MOD 1 in MMBasic
and MOD seems to only works on integers so will always give zero.
It would be worth checking the difference between CINT, INT and FIX if you are likely to have negative numbers.
Anther can of worms.
PRINT "N",,"INT(N)",,"CINT(N)",,"FIX(N)"
FOR n = -2 TO 2 STEP 0.25
PRINT n,,INT(n),,CINT(n),,FIX(n)
NEXT n
RCMAN
I don't!
3
14159
not soo bad!
I was looking for a modulus command used in C
RC
vegipete
Posted: 08:53pm 10 Dec 2020
INT reduces the number by the fractional part - potentially problematic for negative numbers.
CINT rounds to the nearest integer - up or down.
FIX just hacks off the fractional part - the positive or negative value gets closer to zero.
Take your pick...
twofingers
Posted: 09:09pm 10 Dec 2020
@RC
  Quote  I was looking for a modulus command used in C
something like that:
function fract(a as float) as float
 fract=a-FIX(a)
end function
RCMAN
Posted: 09:17pm 10 Dec 2020
  twofingers said  @RC
 fract=a-FIX(a)
end function
I was working out row and column and CaptainBoing example helped me solve that problem.
It's all good now.
One thing out of the way, moving on to animation and background detection.
RC
