Local Time 10:05 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Armmite F4
lew247
Posted: 07:24am 07 Dec 2020
I've been reading all the threads I can find after discovering This M4 thread
As far as I can ascertain there is no manual for the F4 and have to use the H7 manual
but
Is there support in Armmite for the NRF24L01 module in Armmite M4? ie Wi-Fi access
Posted: 10:04am 07 Dec 2020
I think it's known as the Armmite F4 and so F4 thread (or 407VET6) might be better? Might work better in a web search?
I use the H7 manual but had no reason to try the module you mention, sorry.
What happens if you do?
lew247
Posted: 10:12am 07 Dec 2020
I did try the search and Google search but no definitive answer
I guess the only people who know are Matherp or anyone that used the module
Posted: 10:15am 07 Dec 2020
The is no support for the NRF24L01 in any version of MMBasic. It would need writing in Basic
Posted: 01:06pm 07 Dec 2020
You could do wget with wifi on esp8266 with annex and pass data to Armmite F4, but you'd have to write some stuff which you don't have to do yourself on the pi.
There's no F4 manual that I have found, so I use the H7, but it appears to me that while JSON$ is in the H7 manual, it doesn't work on the F4 (isn't available--though I didn't try an "easy" example).
I dug out a pi-z-w with mmbasic (sketch) yesterday, so if you'd like to post code and data received from wget, I can look at it.
lew247
Posted: 07:52pm 09 Dec 2020
Thanks, I've sent you a message
