Local Time 11:21 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question about keyboard input
RCMAN
Posted: 03:36pm 06 Dec 2020
Hello,
I'm writing a shooting game and I find the CMM2 doesn't accept multiple key presses at the same time.
If I want to control ship movement and press fire at the same time I need to stop moving my ship for it to register another key.
Is there an interupt driven way I can get keyboard input?
I have used keydown and inkey$ and neither seem to allow multiple.
RC
NPHighview
Posted: 03:48pm 06 Dec 2020
I've noticed this as well; "N-key" rollover doesn't work very well on the CMM2.  You can detect a few combination keypresses (Ctrl-arrow keys) in particular, but that's pretty much it.  But, with today's release with Peter working on USB keyboard "up key" detection, it may be worth revisiting.
I wrote a little keyboard monitoring program to display all seven or eight of the values in the keydown() array, and took notes on what key combos work.  This should be pretty easy to replicate (I'm not at my development computer right now).
RCMAN
Posted: 04:09pm 06 Dec 2020
  NPHighview said  I've noticed this as well; "N-key" rollover doesn't work very well on the CMM2.  You can detect a few combination keypresses (Ctrl-arrow keys) in particular, but that's pretty much it.  But, with today's release with Peter working on USB keyboard "up key" detection, it may be worth revisiting.
I have tried left control and it would not show me anything. I'm not sure why.
I have a similar program that just shows values. I read in the Beta 1 of the firmware this might have been addressed but I have not confirmed.
RC
Posted: 04:27pm 06 Dec 2020
keydown works perfectly within the limitations of the keyboard itself. Keyboards use a matrix scan and depending on where keys are in the matrix they may or may not be able to appear simultaneously
Run the attached to see what your keyboard can do and read the manual for what to expect
do
print @(0,0),str$(keydown(0),4), str$(keydown(1),4),str$(keydown(2),4),str$(keydown(3),4),str$(keydown(4),4),str$(keydown(5),4),str$(keydown(6)),bin$(keydown(7),8)
loop
Edited 2020-12-07 02:27 by matherp
RCMAN
Posted: 04:39pm 06 Dec 2020
  matherp said  keydown works perfectly within the limitations of the keyboard itself. Keyboards use a matrix scan and depending on where keys are in the matrix they may or may not be able to appear simultaneously
do
loop
Thank you. That solved the issue.
RC
