Local Time 09:03 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : IMAGE ROTATE [_FAST]
yock1960
Posted: 11:49am 05 Dec 2020
Has there been an undocumented change or just lagging documentation and/or have I missed the noted change? The current docs say that you can flag the command to ignore black pixels. _FAST accepts the flag parameter, 'unfast' does not (syntax). It's not a huge difference, but when using the command to rotate text to 'any' angle, the quality does noticeably decrease and the black triangles are ugly!
I'm using _FAST, haven't figured out another solution.
Steve
djwildstar
Posted: 09:49pm 15 Dec 2020
I asked this question a while back, and my understanding is that this isn't a bug -- IMAGE ROTATE and IMAGE RESIZE intentionally lack the optional flag to ignore black pixels.  The documentation should get updated to reflect that the _FAST versions take the flag while the non-fast (bilinear) versions do not.
As a work-around you could use IMAGE RESIZE or IMAGE ROTATE as appropriate to scale and rotate your image, and then use IMAGE RESIZE_FAST with 1:1 scaling (new width and height the same as existing width and height) to copy the image without writing black pixels.
Posted: 10:38pm 15 Dec 2020
Why not read the release notes and/or manual for V5.06.00?
