Local Time 11:21 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sticky keys
jirsoft
Posted: 11:36pm 04 Dec 2020
I'm not sure, if it was in every FW until now (I think yes), but sometimes are some keys "sticky" = I'm not pressing any key and also didn't do it before, so keyboard buffer should be empty, but key is repeated forever. I can reproduce it in Napoleon Commander with ENTER key on longer directory, where after pressing ENTER program reads names and sizes from SD, but then is like ENTER were still pressed. It works this way (for me) for example in Gaunlet/SOUND/NARRATOR. It helps when I press for example cursor down (but it have to be in right moment).
I'm not able to solve it in my program, it doesn't matter what for OPTION CRLF is set, also different values of KEYBOARD REPEAT make no change. I have wireless USB keyboard from Logitech.
Has anybody such experience and found solution?
Jiri
vegipete
Posted: 01:03am 05 Dec 2020
Yes, from time to time I get phantom auto-repeating keys. Why? I haven't figured out why yet, nor what conditions contribute. I need to determine if it only happens when connected via USB-B to Teraterm or whether it happens with a mains adapter too.
toml_12953
Posted: 01:28am 05 Dec 2020
  vegipete said  Yes, from time to time I get phantom auto-repeating keys. Why? I haven't figured out why yet, nor what conditions contribute. I need to determine if it only happens when connected via USB-B to Teraterm or whether it happens with a mains adapter too.
It's happened to me with a USB (US) keyboard.
yock1960
Posted: 02:05am 05 Dec 2020
Ditto...usually cursor down for me.
jirsoft
Posted: 11:37am 05 Dec 2020
I have it also in EDITOR, but there I'm already prepared and after more destructive action like copy/move part of program (I have to few times to delete 10 more copies done by sticky keys) or delete few lines (sometimes delete try to delete firsts line not to be deleted, but at least char by char), I'm already prepared and after action press cursor down or up.
But in EDITOR is bad (sometimes very bad), but it can be somehow improved by nonstandard key pressing, in program is driving me crazy...
Jiri
jirsoft
Posted: 06:44pm 05 Dec 2020
Looks like Peter solved the issue in last RC1, many thanks!!!
Jiri
