Local Time 11:21 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM+ 100pin with SSD1963 in 16bit mode
panky
Posted: 04:01am 01 Dec 2020
I would like to drive an SSD1963 7" lcd in 16 bit mode with an MM+ 100 pin - is this possible and if so, what are the MM+ 100 pin connections for D8 through D15.
Any help/advice appreciated.
Doug.
disco4now
Posted: 05:20am 01 Dec 2020
Hi Doug,
I have driven some 16bit screens from Peters MX470 64 boards,and looked at the E100.
I think you will need to compile a loadable driver for it, but is doable.
On the 64 bit board I used the following pins.
Data Bit   Pin     Register
D8         14      RB2
D9         13      RB3
D10        12      RB4
D11        11      RB5
D12        17      RB6
D13        18      RB7
D14        21      RB8
D15        22      RB9
You need to find 8 pins. It is nice if they are sequential and on the same register, this makes writing out the data easier/faster. You have to look at what you give up based on the pins you select. i.e com ports, PWM etc. A balancing act.
On the E100 you would have to patch them to the D8-D15 pins on the SSD1963 socket.
I could compile it for you if you nominate the pins.
Probably from 8 from the RB2 to RB15 range that least impact the use of the other functions.
Gerry
Edited 2020-12-01 15:37 by disco4now
F4 H7FotSF4xGT
Posted: 05:54am 01 Dec 2020
I DO remember Peter doing something like that, but I am wondering if it was for the ARMmite and PiCromite only - I may well be wrong.  Hopefully, Peter will see this thread and enlighten us all.
I seem to recall Peter saying back then, that 16-bit did not really give much of a performance boost over 8-bit despite double the data-bus width.  Hopefully, he will remind me about that also if he chimes in here.
Posted: 09:13am 01 Dec 2020
maybe something you can glean from here
http://www.fruitoftheshed.com/MMBasic.LCD%20Panel%20list.ashx?HL=ssd1963
panky
Posted: 09:52pm 01 Dec 2020
Hi Gerry,  Thanks very much for the offer to compile. I am creating my own board and RA0 through RA7 would suit me perfectly.
Data Pins    Register    470/100 pin
 8               RA0           17
 9               RA1           38
 10             RA2           58
 11             RA3           59
 12             RA4           60
 13             RA5           61
 14             RA6           91
 15             RA7           92
Appreciate your assistance,
Doug.
disco4now
Posted: 11:06pm 01 Dec 2020
Hi Panky,
So all the other SSD1963 pins would match the existing values? You could initially test as 8 bit with the in built software for the MM2.
The 16 bit CFunction driver could support transparent text, but I don't think you would have support for the BLIT command.
Gerry
F4 H7FotSF4xGT
panky
Posted: 11:39pm 01 Dec 2020
LCD-D0 through LCD-D7 are standard E100, as are all control signals.
Doug.
PS. PCB still in the process of design - have not decided if I will go with a Chinese manufacturer or try a local (even if more expensive). D.
Posted: 03:05pm 02 Dec 2020
Way out of date but
https://www.thebackshed.com/forum/ViewTopic.php?TID=9025&PID=98526#98526
