Local Time 12:24 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : It seems our site certivicat has expired.
mclout999
Posted: 06:43pm 29 Nov 2020
Just a note that I am not able to visit post now without a lot of mishegoss and futzing about.  It was good until the 28thv, or so Chrome says.
mclout999
Posted: 06:50pm 29 Nov 2020
Apparently, I can't spell either(this is well documented with me).  That was certificate. On this site, Grammarly is very slow for some reason and the highlights of errors are way offset down below the text you are writing. Hay, anyone have a better grammar/spellchecker they can suggest?  Thank.
epsilon
Posted: 09:07pm 29 Nov 2020
Yes, same issue here, using Firefox. The site's SSL certificate has expired.
Epsilon CMM2 projects
Posted: 09:10pm 29 Nov 2020
Gizmo knows and is sorting it out.
It should have automatically updated but something went wrong with the process.
Once you set an exemption in Firefox, it won't annoy you again.
Posted: 11:23pm 29 Nov 2020
Yes. Trying to sort this. Unfortunately the process of installing a SSL cert on a IIS web server is a total head f$%k and the link to instructions from the provider goes to a blank page. I remember last time it took me half a day to sort it. Total BS.
LeoNicolas
Posted: 12:16am 30 Nov 2020
Have you thought about moving the site to Linux / Apache or Nginx?
mclout999
Posted: 12:20am 30 Nov 2020
  [ said  QUOTE=
I can't not figure out how to do that in Chrome any Idea?
Posted: 12:53am 30 Nov 2020
  LeoNicolas said  Have you thought about moving the site to Linux / Apache or Nginx?
On more than one occasion. Problem is some content on the site uses ASP, so requires IIS.
I think I have the new cert installed
SimpleSafeName
Posted: 01:00am 30 Nov 2020
Seems to work fine here.
Turbo46
Posted: 01:27am 30 Nov 2020
Thanks Glenn.
LeoNicolas
Posted: 05:25am 30 Nov 2020
Is it possible to convert these ASP files to PHP? If yes, I can help doing this conversion.
