Local Time 12:23 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Napoleon Commander - VIewers and Actions?
jirsoft
Posted: 03:01pm 23 Nov 2020
Hi all NC users (if there is more than one),
I'm looking for the ideas for anyVIEWER (F3 key) or ACTION (ENTER key) needed for NC. Something could be built-in, something maybe as external.
Right I'm (slowly) preparing C64 packet (some image formats, maybe also 6502 code viewer from my new project), more images general (not just simple viewer, but with informations - size, colors etc.), extending BAS viewer (right now just lists all FUNCTIONs and SUBs)...
If you have some ideas (or better are you willing to participate it as external viewer/action), please let me know.
I wouldn't like to change NC into big slow duck, but some useful functions coul be good.
Jiri
Posted: 10:28am 24 Nov 2020
The thing I used most when using NC was the hex viewer and editor.
Graphics where rare in the days ...
jirsoft
Posted: 11:25am 24 Nov 2020
  Volhout said  The thing I used most when using NC was the hex viewer and editor.
And the HEX viewer in Napoleon is OK for you? It can be forced for every file with ALT-F3 (it's in the manual, but I forgot it in shortcut section...)
I'm preparing now elementary HEX editor for F4, it will be simple but not limited by file size. For more sofisticated work you can use HEXEDIT from epsilon.
Jiri
paceman
Posted: 11:26am 24 Nov 2020
Hi Jiri,
I certainly find it useful. I also reworded your "MANUAL.TXT" file on my system to improve the English readability. It is here
NC MANUAL.zip
 if you want to substitute it for your original.
Greg
jirsoft
Posted: 12:43am 25 Nov 2020
  paceman said  Hi Jiri,
NC MANUAL.zip
Greg
Hi Greg,
thank you, I uploaded manual with your changes, but because in the meantime I have put into NC some new features, it's extended again. If you are ready to check it again direct from GitHub, it helps me, also any texts from F1 Shortcuts or About...
Format of MANUAL.TXT is 35 rows for every page, in one row should be maximum of 98 char (100 - 1 space left and 1 space right), because text viewer from NC is scrolling just by pages.
Jiri
paceman
Posted: 12:39pm 25 Nov 2020
Hi Jiri,
OK, will do. I've been busy with grandchildren today but will check it out tomorrow.
Greg
jirsoft
Posted: 12:44pm 25 Nov 2020
Greg
Don't rush! And thank you...
Jiri
paceman
Posted: 01:38pm 27 Nov 2020
Hi Jiri,
I've edited the Manual.txt file again and the Shortcut/About section of the NC.bas files - both were V0.63.
I'm not sure whether the 'LALT' is a typo or not shortcut(13) so I've left it.
Files are here
MANUAL.zip
and here.
Shorts and Abouts.zip
Greg
jirsoft
Posted: 08:34pm 27 Nov 2020
Files are here
MANUAL.zip
and here.
Greg
Hi Greg,
thanks a lot! I will incorporate it over weekend...
Jiri
