Local Time 14:26 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MATH Matrix Commands
toml_12953
Posted: 11:24am 20 Nov 2020
Adding the matrix commands to MMBASIC was a good idea. Are there any plans to add
MATH M_INVERT, MATH M_ADD and MATH M_READ?
These would eliminate a lot of programming and loops in some programs.
option base 1
dim a(2,2)
math m_read a()
data 1,5,8,2
print"Output:"
math m_print a()
Output:
1, 5
8, 2
LeoNicolas
Posted: 03:36pm 20 Nov 2020
Indeed. And the same for vector.
Another command that can be very useful is math v_slice or v_copy
Option base 0
Dim s(4)=(1,2,3,4,5)
Dim d(2)
Math v_slice v(), 1, d()
The second argument is the position from de source vector to start copying the data.
D will be (2,3,4).
