Local Time 14:26 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMDEBUG suggestion
jirsoft
Posted: 01:49pm 17 Nov 2020
Hi Peter,
couldn't be MMDEBUG made a little different way:
When #MMDEBUG ON doesn't exist (or is OFF), complete row after MMDEBUG will not be included. So I can write for example
MMDEBUG CLS
MMDEBUG IF a=5 THEN PRINT
It shouldn't be so hard and will be much more useful... Otherwise is debugging perfect way!
Until now I used simple library (as DEBUG.INC), so I will not make NOT DEBUGed code slower:
CONST MAX.DBG = 20            'maximal number of watched vaiables
DIM STRING DBG.DBG(MAX.DBG)   'DEBUG watchlist
DIM INTEGER LEN.DBG = -1      'current number of watched variables
DIM INTEGER ON.DBG = 0        'DEBUG ON or OFF
DIM INTEGER PERIOD.DBG = 1000 'output period in ms
DIM INTEGER X.DBG=0, Y.DBG=0  'screen coordinates for output
'*** SUBs and FUNCTIONs ***
'DBGon(period, x, y)  switch DEBUG ON and set output to every period in ms at @(x,y)
'DBGoff               switch DEBUG OFF
'DBGout               print DEBUG informations
'DBGadd(variable)     add var to watchlist, string var have to end with $
'                     INTEGER/FLOAT var can be prefixed with &N for HEX output with N digits
'DBGdel(variable)     remove var from watchlist
SUB DBGon(period AS INTEGER, x AS INTEGER, y AS INTEGER)
 ON.DBG = 1
 IF period = 0 THEN period = 1000
 X.DBG = x:Y.DBG = y
 DBGout
 SETTICK period, DBGout, 4
END SUB
SUB DBGoff
 ON.DBG = 0
 SETTICK 0,0,4
END SUB
FUNCTION DBGfind(elm AS STRING) AS INTEGER
 LOCAL INTEGER i, f = -1
 FOR i = 0 TO LEN.DBG
   IF LCASE$(elm) = LCASE$(DBG.DBG(i)) THEN
     f = i
     EXIT FOR
   ENDIF
 NEXT i
 DBGfind = f
END FUNCTION
SUB DBGout
 LOCAL INTEGER i, h =MM.INFO(FONTHEIGHT)
 LOCAL STRING s, q = CHR$(34)
   IF INSTR(DBG.DBG(i),"$") = 0 THEN
     IF LEFT$(DBG.DBG(i),1)="&" THEN
       's="HEX$("+MID$(DBG.DBG(i),3)+"," + MID$(DBG.DBG(i),2,1)+")"
       '?s:ERROR"STOP"
       s = MID$(DBG.DBG(i),3) + "=" + EVAL("HEX$("+MID$(DBG.DBG(i),3)+"," + MID$(DBG.DBG(i),2,1)+")")+"   "
     ELSE
       s = DBG.DBG(i) + "=" + EVAL("STR$("+DBG.DBG(i)+")   ")
     ENDIF
   ELSE
     s = DBG.DBG(i) + "=" + q + EVAL(DBG.DBG(i)) + q+ "   "
   ENDIF
   TEXT X.DBG, Y.DBG + i*h, s
 NEXT i
END SUB
SUB DBGdel(elm AS STRING)
 LOCAL INTEGER i, f = DBGfind(elm)
 IF f <> -1 THEN
   IF f < LEN.DBG THEN
     FOR i = f TO LEN.DBG
       DBG.DBG(i) = DBG.DBG(i+1)
     NEXT i
   ENDIF
   LEN.DBG = LEN.DBG - 1
 ENDIF
END SUB
SUB DBGadd(elm AS STRING)
 IF DBGfind(elm) = -1 THEN
   IF LEN.DBG < MAX.DBG THEN
     LEN.DBG = LEN.DBG + 1
     DBG.DBG(LEN.DBG) = elm
   ENDIF
 ENDIF
END SUB
Jiri
Posted: 02:00pm 17 Nov 2020
  Quote  When #MMDEBUG ON doesn't exist (or is OFF), complete row after MMDEBUG will not be included.
That is what it does now
jirsoft
Posted: 03:32pm 17 Nov 2020
Maybe I was not precise enough, I would like to have ANY command after MMDEBUG, right now is possible just with MMDEBUK BREAK break the code or with MMDEBUG something print something.
But I thought it will be perfect to be possible:
MMDEBUG CLS
MMDEBUG TEXT...
MMDEBUG IF a = 5 THEN PRINT something
So I have code parts, that will be included just when needed for debugging.
Jiri
Posted: 03:41pm 17 Nov 2020
No - sorry. To do it would add an extra layer to all commands which would slow normal operations down plus be a huge task. Doesn't matter with PRINT as that is an inherently slow command
jirsoft
Posted: 06:29pm 17 Nov 2020
OK, understood. I thought MMDEBUG commands are in case of #MMDEBUG OFF (or missing) replaced with ' (REM) in preprocess phase, so it will be easy. It's pity...
Jiri
jirsoft
Posted: 06:30pm 17 Nov 2020
Can't this be built in into EDITOR?
Jiri
Posted: 07:29pm 17 Nov 2020
No
Posted: 08:01pm 17 Nov 2020
@jirsoft you *may* be able to achieve some of what you are asking for using sptrans.
If you have questions about it please start a new thread. Also I'm unable to act on any enhancement requests at the moment.
jirsoft
Posted: 07:50am 18 Nov 2020
  thwill said  @jirsoft you *may* be able to achieve some of what you are asking for using sptrans.
Thanks Tom,
it looks good and for sure can be used for this, but I was looking for some "more standard way. When I need to change it "extern" (in app), it will be fastest way to write some small, specific tool...
Jiri
