Forum Index : Microcontroller and PC projects : 5.05.06RC18 on CMM2 - please HELP
| jirsoft Guru Joined: 18/09/2020 Location: Czech RepublicPosts: 533 |
Hi, I have issue with the 5.05.06RC18. Since error in my program (I copied SUB to change later name of copy to new one), I'm getting all the time Error in line 1200: Duplicate name Problem is, I can't do anything, NEW, CPU RESTART, UPDATE FIRMWARE... all the time the same error. What can I do? When I reset CMM2 on the back connector, it will be empty? Can I then update firmware through A-B cable? My model is 400 MHz without Waveshare card... Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), CMM2.fun |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12085 |
No: it just deletes the program and resets the options to default. Nothing you can do will stop you being able to upload new firmware as this uses a bootstrap which is part of the chip itself. This bug will be fixed in RC20 which will be out today Edited 2020-11-16 22:56 by matherp |
Thanks Pater, I set the jumper to PROGRAM, updated FW to RC19 and after jumper to RUN everything works... Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), CMM2.fun |
