Local Time 16:33 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximum font size?
MustardMan
Posted: 09:55pm 14 Nov 2020
I would like to create a custom font to display probably four or five large, single colour images (ie: 4 or 5 characters).
A font is defined such (pseudocode):
DefineFont #n
 aabbccdd xxxxxxxx ...
End DefineFont
where aa = number of characters, bb = first character, cc = height, dd = width
which implies a maximum character size of 256x256 pixels.
FontTweak (to my knowledge) won't allow fonts anywhere near this big, so I was wondering if there was a size limit other than the sort-of-implied 256?
Cheers,
Edited 2020-11-15 08:08 by MustardMan
Posted: 10:08pm 14 Nov 2020
FontTweak has a sanity check which stops you creating fonts that large but it will open and allow you to edit them if required.
The biggest I have tried is 240 x 64
MustardMan
Posted: 12:42am 15 Nov 2020
Hi Jim,
Thanks for the quick reply! I wonder what you guys do all day - it seems whenever something is posted, everyone is onto it straight away! I wish I had time for that
Using FontTweak I can open my bitmap (256x256) which it then defaults to import at 79x92, then double size and re-import, giving a size of 158x184. I think that will look quite nice.
When I was creating my font I noticed that adding a character (^N) duplicated the first character into the second (or was that the other way around?). Anyway it was not a big deal as once I noticed that I just created a font with everything empty, then went through and filled in the correct symbols.
Cheers,
Edit: It would appear the initial size  (79x92) was simply because that was the last font size I edited and had nothing to do with the imported bitmap size. Unusual size... would have expected multiples of 8...
Edited 2020-11-15 12:46 by MustardMan
jirsoft
Posted: 09:43am 16 Nov 2020
for playing with the fonts, you can modify my simple app, I used it for the creating the font for Napoleon Commander from Atari ST bitmap>
OPTION DEFAULT NONE
OPTION EXPLICIT
OPTION BASE 0
CONST INP.FNT = "AtariST.BMP"   'input file name
CONST OUT.FNT = "AtariST.FNT"   'output file name
CONST CHR_W.FNT = 8             'char width in pixels
CONST CHR_H.FNT = 16            'char height in pixels
CONST BMP_W.FNT = 128           'BMP width in pixels
CONST TOPLEFT.FNT = 32          'first char read from BMP
CONST BOTRIGHT.FNT = 255        'last char read from BMP
CONST FIRST.FNT = 32            'ACII of first char
CONST INVERT.FNT = 1            '0=WHITE on BLACK, 1=BLACK on WHITE (can be used to invert font)
convChar
END
SUB convChar
 LOCAL INTEGER ww = BMP_W.FNT / CHR_W.FNT
 LOCAL INTEGER hh = 32/CHR_W.FNT
 LOCAL INTEGER x, y
 LOCAL INTEGER xx, yy, col, bright, b, ch, cpl = 0
 LOCAL STRING h = ""
 LOAD BMP INP.FNT
 OPEN OUT.FNT FOR OUTPUT AS #1
 ?#1,"DefineFont #8"
 ?#1,"  "HEX$(BOTRIGHT.FNT-TOPLEFT.FNT+1,2)HEX$(FIRST.FNT,2)HEX$(CHR_H.FNT,2)HEX$(CHR_W.FNT,2)
 ?#1,"  ";
 FOR ch =TOPLEFT.FNT TO BOTRIGHT.FNT
   x = (ch MOD ww) * CHR_W.FNT
   y = (ch\ww) * CHR_H.FNT
   FOR yy=0 TO CHR_H.FNT-1
     b = 0
     FOR xx=0 TO CHR_W.FNT-1
       col = PIXEL(x + xx, y + yy)
       bright = ((col AND &hFF0000) >> 16) + ((col AND &hFF00) >> 8) + (col AND &hFF)
       IF INVERT.FNT THEN
         IF bright < 382 THEN
           b = b + 2^(CHR_W.FNT - xx - 1)
           PIXEL x + xx, y + yy, RGB(RED)
         ENDIF
       ELSE
         IF bright > 382 THEN
           b = b + 2^(CHR_W.FNT - xx -1)
         ENDIF
       ENDIF
     NEXT xx
     h = HEX$(b,2) + h
     IF LEN(h) = 8 THEN
       ?#1,h" ";
       h = ""
       cpl = cpl + 1
       IF cpl = 8 THEN
         IF ch < BOTRIGHT.FNT THEN
           ?#1
           ?#1,"  ";
         ENDIF
         cpl = 0
       ENDIF
     ENDIF
   NEXT yy
 NEXT ch
 ?#1
 ?#1,"END DefineFont"
 CLOSE #1
END SUB
Jiri
jirsoft
Double post...
Edited 2020-11-16 19:43 by jirsoft
Jiri
