Forum Index : Microcontroller and PC projects : I2C vs I2C2 vs I2C3
| elk1984 Senior Member Joined: 11/07/2020 Location: United KingdomPosts: 232 |
This may be a stupid question, but what was the reasoning behind using I2C2 and I2C3 as commands rather than extending the I2C command to accept a <port> parameter? Wouldn't combining and changing the parameters on the I2C command free up two tokens for other BASIC keywords? |
Like many things MMBasic, it just grew over time. While testing the HT mouse versus my Arduino version, I needed a simple way the swap I2C ports so came up with this SUB SUB I2Cx p%, I2Ccmd$ SELECT CASE p% CASE 1 EXECUTE "I2C "+I2Ccmd$ CASE 2 EXECUTE "I2C2 "+I2Ccmd$ CASE 3 EXECUTE "I2C3 "+I2Ccmd$ END SELECT END SUB The full test program which has been tested on ports 1 and 2 ' ht_mouse test CLS MODE 1 mousePort = 2 initmouse SPRITE LOAD "mouse.spr",1 'pause 100 DO readmouse TEXT 0,0,STR$(x,6,0," ")+STR$(y,6,0," ")+STR$(lb,2,0," ")+STR$(rb,2,0," ")+STR$(sb,2,0," ")+STR$(xs,4,0," ")+STR$(ys,4,0," ")+STR$(ss,6,0," ") SPRITE SHOW 1,x,y,1 PAUSE 30 LOOP UNTIL INKEY$ <>"" SPRITE HIDE 1 I2Cx mousePort, "CLOSE" ' SUB initmouse I2Cx mousePort, "OPEN 100,1000" I2Cx mousePort, "WRITE 41,0,3,20,INT(MM.HRES \ 256),INT(MM.HRES MOD 256)" I2Cx mousePort, "WRITE 41,0,3,20,INT(MM.HRES \ 256),INT(MM.HRES MOD 256)" I2Cx mousePort, "WRITE 41,0,3,22,INT(MM.VRES \ 256),INT(MM.VRES MOD 256)" I2Cx mousePort, "WRITE 41,0,3,24,INT(MM.HRES \ 512),INT((MM.HRES\2) MOD 256)" I2Cx mousePort, "WRITE 41,0,3,26,INT(MM.VRES \ 512),INT((MM.VRES\2) MOD 256)" I2Cx mousePort, "WRITE 41,0,2,28,10" END SUB ' SUB readmouse DO I2Cx mousePort, "WRITE 41,1,1,0" I2Cx mousePort, "READ 41,0,10,s$" x=STR2BIN(UINT16,LEFT$(s$,2),big) y=STR2BIN(UINT16,MID$(s$,3,2),big) lb=ASC(MID$(s$,5,1)) rb=ASC(MID$(s$,6,1)) sb=ASC(MID$(s$,7,1)) xs=STR2BIN(int8,MID$(s$,8,1)) ys=STR2BIN(int8,MID$(s$,9,1)) ss=ss+STR2BIN(int8,MID$(s$,10,1)) LOOP UNTIL x>=0 AND x<MM.HRES AND y>=0 AND y< MM.VRES 'trap missreads END SUB SUB I2Cx p%, I2Ccmd$ SELECT CASE p% CASE 1 EXECUTE "I2C "+I2Ccmd$ CASE 2 EXECUTE "I2C2 "+I2Ccmd$ CASE 3 EXECUTE "I2C3 "+I2Ccmd$ END SELECT END SUB Jim VK7JH MMedit |
