Local Time 17:41 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: keydown not cleared after blit & save image
BruderJo
Posted: 10:27pm 04 Nov 2020
Hello,
I have the following test program.
Once started, it waits for a key.
Press any single letter and you can see, the key is never released.
e.g. "s" has a permanent output of "1  115"
The device does not recognize, that there is nokey pressed.
But as soon as you press the next key, the program stops and works correctly.
Seems, the keydown functions becomes confused by the "page write/blit" statements.
my firmware version is 5.05.05.
option explicit
option default none
option base 0
mode 1,8
cls
dim integer k
dim a$
dim string Fname = "dummy.bmp"
do
 a$=inkey$
loop until a$ <> ""
k=keydown(1)
do while inkey$ <> "": loop
page write 2
blit 0,0,0,0,MM.HRES,MM.VRES,0
page write 0
blit 0,0,0,0,MM.HRES,MM.VRES,1
save image Fname,0,0,512,256
blit 0,0,0,0,MM.HRES,MM.VRES,2
page write 0
do
 print keydown(0), keydown(1)
loop until keydown(0) = 0
end
panky
Posted: 01:34am 05 Nov 2020
@BruderJo
Tested with 5.05.06 and works OK. One thing to note, your final do-loop cycles VERY fast and even for a relatively short keypress will still go through the loop hundreds if not more, of times.
I put a 100mS pause in that final loop and you can then see the keydown reported while a key is pressed and end correctly when the key is released.
Doug.
BruderJo
Posted: 06:42am 05 Nov 2020
The code is only to demonstrate the issue without any tuning.
A "pause 100" within the final do-loop only delays the my output, but the result is the same.
BUT!
a "pause 100" right before the first "page write 2" is a solution.
The only output is now "0  0", what I always expected.
Maybe I ran into a timing issue and should go for an update.
btw: I own the pre-assembled version.
Posted: 08:01am 05 Nov 2020
  Quote  my firmware version is 5.05.05
Upgrade to 5.05.06RC13 - definitely fixed (at least with any of my keyboards)
Edited 2020-11-05 18:01 by matherp
BruderJo
Posted: 11:10am 05 Nov 2020
confirmed: 5.05.06rc13 solved it.
