Local Time 17:41 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 - speed optimisation notes
jirsoft
Posted: 09:46pm 04 Nov 2020
Hi all,
while working on emulator, where I need maximum speed, I found until now fow points/ideas, which could be usable by others too (Peter knows it, but I didn't find it anywhere written)...
1. Hex constant are faster than decimal, with exception of negative numbers. So p = p + &h1 is faster than p = p + 1 (Also spaces make it a little bit slower, but not so much)
2. CSUBs are called faster when defined without parameters also in case they are defined (and needed) in C-file
CSUB action
END CSUB
Then called as action par1, par2
3. Logical functions are fast, mainly in combination with hex constants
4. Computed propertities faster then IFs
zero = (x = &h0)<<&h1
is faster than
IF x=0 THEN zero=2 ELSE zero=0
5. BYTE access into memory reserved as array is faster with help if LONGSTRINGs than PEEKs/POKEs, but marginally and not so cozy
Not so many, but maybe good start for quick guide...
Jiri
