Local Time 17:42 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 - update firmware MacOS
jirsoft
Posted: 03:55pm 04 Nov 2020
did somebody of you have luck to update firmware of CMM2 on MacOS? I know the GUI version of STM32CubeProgrammer has issues, but it should be possible with CLI. I'm able to run the SW, but I have no experience with it (until now I'm updating firmware on Win8 im VMware, but I'm looking for easier method).
If somebody already tried it and was successful, what settings should I use?
Thanks.
Jiri
Sasquatch
Posted: 12:58am 05 Nov 2020
  jirsoft said  Hi,
Thanks.
See this thread:
Update firmware on Mac
This is now my preferred method for updating the firmware on CMM2.  It only takes maybe 30 seconds for the entire operation.  I keep the commands in a text document and then just a quick edit-copy-paste into the terminal window and done.
Edited 2020-11-05 11:28 by Sasquatch
-Carl
LeoNicolas
Posted: 05:55am 05 Nov 2020
I have done the update from a Linux machine. What I'm doing is running the STM32CubeProgrammer as a super user.
jirsoft
Posted: 12:56pm 05 Nov 2020
  Sasquatch said
See this thread:
Thanks a lot! I will try it today...
PS: I have already done quick&dirty app for compile C function, make CSUB of it and either SAVE or send through serial to CMM2, so I will just extend it for firmware update function. If someone wants the app, I can store it somewhere (Xojo, so Macos, but I can compile it for Linux or Windows). The paths to ggc/ld (and now STM32_Programmer_CLI) can be modified...
Jiri
LeoNicolas
Posted: 05:02am 06 Nov 2020
  jirsoft said
  Sasquatch said
See this thread:
Hey Jiri
I was thinking of converting the basic program that is used for creating the CSUB from the compiled C code to Python. Python is a good language to do it because it supported for all platforms and it is not necessary to compile the code.
Maybe I can do it from your C code. Could you share your source code through Github?
jirsoft
Posted: 10:02am 06 Nov 2020
Hi Leo,
I can do it, it's actually BASIC code (XOJO is RealBasic child), but I have taken it from Peter's MMBASIC code (it's in every update). The reason, why I did it is, that I can drop C file on app, look for errors in the windows and when is OK, it created CSUB, that can be directly sent to CMM2 (I simply point cursor im CMM2 EDITOR and receive CSUB).
I put it on Github this weekend inclusive compiled code...
Jiri
LeoNicolas
Posted: 07:44pm 06 Nov 2020
I'm using Linux and to convert the binary file to CSUB using the MMBasic code is not straightforward. Any other solution will help a lot
jirsoft
Posted: 03:04pm 07 Nov 2020
Hi Leo,
I have put the source and binaries for MacOS and Linux into Github ELF2CSUB. The app is also able to update firmware, but TESTED JUST IN MACOS!!!. You need to have installed arm-none-eabi-gcc and arm-none-eabi-ld from ARM for compiling of the .c source and STM32_Programmer_CLI from ST for firmware update (paths are configurable in CONFIG).
Jiri
jirsoft
Posted: 03:11pm 07 Nov 2020
  Sasquatch said
  jirsoft said  Hi,
Thanks.
See this thread:
Hi Carl,
thanks a lot for your help, I included your methods in my CMM2 app and it's working perfectly. I'm using the virtual serial port and it takes about 150 sec to update...
Jiri
Sasquatch
Posted: 04:18pm 07 Nov 2020
Hi Carl,
You're very welcome!  I'll check out your CMM2 app when I get a bit of time.  Using a USB A-A cable with a USB2 port on my MacBook Pro it takes about 11 seconds to update the firmware and then another ~15 seconds to verify.
Edited 2020-11-08 02:19 by Sasquatch
-Carl
LeoNicolas
Posted: 05:04pm 07 Nov 2020
I've tried to update my CMM2 via USB port but the computer even turns on. I'll try to buy a new USB A-A cable.
jirsoft
Posted: 05:12pm 07 Nov 2020
  Sasquatch said
Hi Carl,
For me is an advantage to use virtual serial, because I have it still connected to iMac for CSUB development. So, the speed is no so big issue for me...
Jiri
