Local Time 18:41 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: arbitrary memory copy routine ?
Posted: 02:02pm 29 Oct 2020
Is there a command for arbitrarily copying bytes of memory around that I have missed, e.g.
BLIT MEM src_adr, dst_adr, num_bytes
If not then could it be added to the list of possibilities for 5.05.07, I don't think there are enough ways for us to crash the firmware
Seriously though it would be useful for more efficient string storage and implementation of some datastructure manipulations such as insertion into an array without having to resort to a CSUB.
Edited 2020-10-30 00:04 by thwill
Posted: 02:20pm 29 Oct 2020
Try
MEMORY COPY sourceaddress, destinationaddres, numberofbytes
You can also try:
MEMORY SET address, byte, numberofbytes
MEMORY SET BYTE address, byte, numberofbytes
MEMORY SET SHORT address, short, numberofshorts '2 bytes per short
MEMORY SET WORD address, word, numberofwords '4 bytes per word
MEMORY SET INTEGER address, integer, numberofintegers '8bytes per integer
MEMORY SET FLOAT address, float, numberoffloats '8 bytes per float
Posted: 02:27pm 29 Oct 2020
  matherp said  Try
Wow, when did we get those
Please note they do not appear to be in the manual accompanying the lastest firmware RC.
NPHighview
Posted: 03:23pm 29 Oct 2020
I suspect Peter has many such tricks up his sleeve :-)  And documentation always lags :-(
MustardMan
Posted: 01:35am 30 Oct 2020
Very nice!
Is this a CMM specific addition, or does it apply to lower grade devices as well (I have an Explore 100: PIC32MX470)?
Cheers,
Posted: 03:23am 30 Oct 2020
  MustardMan said  Very nice!
Cheers,
Only CMM2 but some of the new functions will filter down to the other variants.
It is a useful addition to the MATHs functions.
As a test, I filled  a subset of elements in an array.
Useful for clearing part of an array or moving data arround quickly.
dim integer bigarray(20)
dim integer n, x, addr, startfill
x = 99
'find the starting address of the target array
addr = PEEK(VARADDR bigarray())
' set the starting point to the 5th array element
startfill = addr + 8*5
' fill 10 array elements starting at element 5
memory set integer startfill, x, 10
'show the results
for n = 0 to 20
print n,bigarray(n)
next n
Output:
0 0
1 0
2 0
3 0
4 0
5 99
6 99
7 99
8 99
9 99
10 99
11 99
12 99
13 99
14 99
15 0
16 0
17 0
18 0
19 0
20 0
Posted: 04:00pm 30 Oct 2020
New functionality in RC10 just posted
MEMORY SET INTEGER address, integervalue ,numberofintegers [,increment]
MEMORY SET FLOAT address, floatingvalue ,numberofloats [,increment]
MEMORY COPY INTEGER sourceaddress, destinationaddress, numberofintegers [,sourceincrement][,destinationincrement]
MEMORY COPY FLOAT sourceaddress, destinationaddress, numberoffloats [,sourceincrement][,destinationincrement]
Together these allow you to crash the system in more ways than you can imagine but more importantly they allow for very fast copies between single and multidimensional arrays i.e array slicing. In all cases the increments default to one unless specified.
option explicit
option default none
dim float sourcearray(3,39),destinationarray(39),d2array(39),x=99.99
dim integer n, addr, addr2, addr3
'find the starting address of the source 2 dimensional array
addr = PEEK(VARADDR sourcearray())
'find the starting address of the first desination 1 dimensional array
addr2 = PEEK(VARADDR destinationarray())
'find the starting address of the second desination 1 dimensional array
addr3 = PEEK(VARADDR d2array())
' fill 160 array elements starting at element 0,0
memory set float addr, x,160
'now make some changes to the source array to prove it all works
for n=0 to 39: sourcearray(2,n)=n:next n
'copy the sourcearray(0,all) to destinationarray
memory copy float addr, addr2,40,BOUND(sourcearray(),1)-BOUND(sourcearray(),0)+1,1
'now point to the start of the second dimension in the source array
addr = addr + 8*2
'copy the sourcearray(2,all) to destinationarray2
memory copy float addr, addr3,40,BOUND(sourcearray(),1)-BOUND(sourcearray(),0)+1,1
'show the results
for n = 0 to 39
 print n,sourcearray(0,n),sourcearray(2,n),destinationarray(n),d2array(n)
next n
For large arrays this will be massively faster than using Basic FOR loops
Edited 2020-10-31 03:07 by matherp
twofingers
Posted: 06:43pm 30 Oct 2020
Hi Peter!
  matherp said  ... in RC10 just posted
Where?
Michael
Posted: 06:51pm 30 Oct 2020
  Quote  Where?
Usual place
http://geoffg.net/Downloads/Maximite/CMM2_Beta.zip
twofingers
Posted: 06:57pm 30 Oct 2020
  matherp said
  Quote  Where?
Usual place
Contains CMM2V5.05.05RC9.bin
Posted: 06:59pm 30 Oct 2020
  Quote  Contains CMM2V5.05.05RC9.bin
Try clearing your cache or similar and try again - works for me
twofingers
Posted: 07:07pm 30 Oct 2020
I confirm.
