Local Time 18:40 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : HC-12
Posted: 03:34pm 27 Oct 2020
Has anyone worked with HC-12 modules ? They default to 9600baud, and using AT commands you can change the baudrate.
Question is: do they memorize the baudrate ?
I have a remote system that cannot send data (init the HC-12) at 9600baud, so I need a PC to set the HC-12 to 2400baud, disconnect, and need it to cold boot after that running 2400 baud.
Thanks in advance for your response,
CircuitGizmos
Posted: 04:16pm 27 Oct 2020
See this thread (and more threads):
http://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=12927
Posted: 08:14am 28 Oct 2020
Thnx
Posted: 08:45am 28 Oct 2020
Yes, they remember the set baudrate.  Pull the SET line low to enter programming mode, when you pull the SET line high again, the new settings take effect, and are used if you cycle the power.
