Local Time 19:45 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : File Properties
elk1984
Posted: 05:37am 27 Oct 2020
I've found the DIR$ command, and I can get a filesize by opening it and using LOF(), but is there something where I can get the date created, last modified, size etc. using a function?  LIST FILES returns details like this, but I'm not sure I can capture and parse that output?
elk1984
Posted: 06:36am 27 Oct 2020
  Quote  MM.INFO(modified f$)
MM.INFO(FILESIZE f$)
elk1984
Posted: 04:40pm 27 Oct 2020
Thanks TassyJim - a bad case of Read The Manual
