Local Time 19:45 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New 121-core processor for the CMM2... ;)
Posted: 08:54am 24 Oct 2020
This is rather interesting for an older CPU.  Perhaps Peter can port the CMM2 to it.
Dave certainly seems to like it!
New CPU for the CMM2!!! ;)
63-layer module, 400 meters of interconnecting wire, 76,000 vias, 121 cores and could access up to 9GB of RAM - in 1991.....
If they could do this in the early 90's, it makes you wonder what they are cooking up in the labs these days.
Skynet is coming!
Posted: 09:43am 24 Oct 2020
Grogster,
Peter will get it going if you buy a few samples for him..
M
Posted: 10:36am 24 Oct 2020
LOL!
bigfix
Posted: 11:11am 24 Oct 2020
The challenge would be the plumbing for the watercooling...
DEC played with waferscale ECL in the 80s - no Hybrid, just plain Silicon
I think the needed about a Kilowatt per wafer - and never really worked
Trilogy Failure
Talking about small micros today:
Dazzler
I guess this has more cores in the GPU for 40 USD
Only for the Arduino world - no Mitesupport so far...
Edited 2020-10-24 21:18 by bigfix
Posted: 11:38am 24 Oct 2020
  Quote  DEC played with waferscale ECL in the 80s - no Hybrid, just plain Silicon
Way back when I was involved in a project for GCHQ in the UK. The H/W we were building used ECL for a framebuffer (way before PC graphics cards).
The power supply for the system was 300amp 5V
Paul_L
Posted: 08:58pm 24 Oct 2020
That module was built in the East Fishkill facility which is about 4.7 miles from my current house. LINK
J. W. Knickerbocker used to own a house 300 feet east of my current house.
The East Fishkill facility was spun off by IBM to Global Foundries about 2007 and will soon transition to ON Semiconductors. It now contains one of the world's 300 mm fabs producing 14,000 wafers per month. Search for "Fishkill" at LIST OF FABS
Those IBM guys sure were ahead of their time back 30 years ago!
Paul in NY
Edited 2020-10-25 07:01 by Paul_L
RetroJoe
Posted: 10:07pm 24 Oct 2020
That thing is insane - like something they have hidden away in Area 51 :) And, when the guy started pushing the caps around in the mineral oil, I thought I was watching a Ridley Scott movie!
Edited 2020-10-25 08:08 by RetroJoe
Enjoy Every Sandwich / Joe P.
hitsware2
Posted: 03:39am 25 Oct 2020
  bigfix said
Dazzler
Neato !
I ' ve been looking for a ' developement board ' with HDMI ....
my site
bigfix
Posted: 09:08pm 25 Oct 2020
I had a closer look at Dazzler
Looks actually quite interesting:
GPU: BT815 1.1 gigapixel/s embedded GPU with 8 Mbyte flash
FPGA: Xilinx Spartan-6 LX9 FT256 with 8 Mbyte flash
Video output: HDMI 24-bit at 1280x720 (720p) with 48 KHz stereo audio
Storage: microSD slot
Extra input: two Wii Classic controller ports
Form-factor:
Gameduino 3X Dazzler is an Arduino-compatible shield
The shield includes the Dazzler Core, which is an SMD module that includes GPU, FPGA, and HDMI
Hardware interfaces:
Standard SPI up to 36 MHz for Arduino communication
UART up to 1 Mbps for FPGA connection
JTAG for FPGA reloading
All inputs are 5 V tolerant
Programming: Gameduino library for Arduino and CircuitPython. Dozens of examples.
Terminal mode: functions as an ANSI terminal with high-speed UART
Current consumption (typical): 180 mA
Dimensions: 83 mm x 53 mm x 20 mm
So in theory you just hook it up to any Mite on SPI and the serial consoleport
I do not find any details - but the Console should see a plain ANSI VT100 ??
Then you need "only" some magic code to drive the GPU over SPI - this is the hard part...
But overall this looks like an affordable external HDMI Graphic subsystem
All open source static Code - no dynamic/moving-target OS like in the Raspberry
hitsware2
Posted: 11:34pm 25 Oct 2020
Hopefully ( for my purposes ) ,
It will act like a glorified Pi Board ....
Shows up as a USB drive .... ( on R Pi )
When you save the main.py file , it runs .
my site
retepsnikrep
Posted: 11:18am 26 Oct 2020
I winced when he mashed up one of the chips with his pliers.. :(
Should have cleaned it all and mounted it in a nice frame on the wall.
I use a huge old expensive faulty IGBT module as a dead as a doorstop in my workroom.
Gen1 Honda Insights.
