Forum Index : Microcontroller and PC projects : Of mice and men err ... I2C
bigmik![]() Guru Joined: 20/06/2011 Location: AustraliaPosts: 2983 |
Hi All, Probably best addressed to Peter, but with the adoption of USB mouse on an I2C port does configuring for a mouse on I2C then exclude that I2C port for use for other I2C devices? Can the USB mouse live on the same port as the NunChuk and both work? Or does each USB (hobbytronics or other) have to have its own I2C port? Regards, MICK Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12086 |
Not now but will be able to You can use any other I2C device on the same port but don't "open" the port - it will already be open at 100KHz baud rate |
Thanks Peter, Great news.. I think it’s nearly time for you to take a holiday.. you must be darn near worn out with the amount of code you create.. I want you to know your efforts are appreciated. Regards, MICK Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
