Local Time 20:50 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Nasty play/run/execute bug that is holding up Welcome Tape
Posted: 05:54pm 13 Oct 2020
Hi Peter,
Here is another one of my freaky examples, I promise the real code isn't such nonsense - it's just the cycle of launching programs from the Welcome Tape and then quitting them to return to the menu:
> list "one.bas"
Print "One"
Play mp3 "TweakerRaySpaceFlight.mp3"
Pause 5000
Execute "Run " + Chr$(34) + "Two" + Chr$(34)
> list "two.bas"
Print "Two"
Pause 500
Execute "Run " + Chr$(34) + "One" + Chr$(34)
> run "one.bas"
One
Two
One
Two
One
Two
One
Error: System fault - possible causes
- Incorrect use of POKE
- Faulty CSUB
- Reserved words used as variables
- Firmware problem
Consistently crashes after the same number of "iterations".
Happens with both OPTION FLASH and OPTION RAM.
I'm assuming the actual .mp3 file doesn't matter, the one I'm using it a bit big to attach, plus I'd need TR's permission.
Posted: 06:23pm 13 Oct 2020
Try it with a PLAY STOP before the execute
Posted: 06:30pm 13 Oct 2020
  matherp said  Try it with a PLAY STOP before the execute
I tried that before, and I have just tried it again. It didn't help. Also tried adding a PAUSE 1000 between PLAY STOP and EXECUTE, it didn't help.
Posted: 06:45pm 13 Oct 2020
The mp3 file may be a red herring:
> list "one.bas"
Print "One"
'Play mp3 "TweakerRaySpaceFlight.mp3"
Pause 50
'Play Stop
'Pause 1000
'Run "Two.bas"
> list "two.bas"
Print "Two"
Pause 10
'Run "One.bas"
> run "one.bas"
One
Two
One
Two
One
Two
One
Two
One
Two
One
Two
One
Two
One
Two
One
Two
One
Two
One
Two
One
Two
One
Two
One
Two
One
Two
One
Two
One
- Faulty CSUB
- Firmware problem
Last week BigMik reported an apparently random crash with the "Welcome Tape" to me that with the benefit of hindsight was probably this.
Edited 2020-10-14 04:46 by thwill
TweakerRay
Posted: 07:16pm 13 Oct 2020
@ tom: would it help if you get the mp3 in a lower quality ? I mean it's in 320kbit/s
I could try to reduce that if that may be too much for the cmm2 ? But I use a 320kbit file in my newest game "HEART ATTACK" and there it plays the music...
@matherp
I also experienced a few times some crashes while starting some of my own programms.
crashes which need to restart the machine. I also saw the error message a few times tom had... randomly...
I checked also some .mod files (for instance in the wolfenstein demo is a folder with .mod files... some play and one will crash my machine: called "alieni_vol_1.mod"
if you have the wolf3d demo you could check that.
Or are some modfiles not for playback ?
http://tweakerray.bandcamp.com
MauroXavier
Posted: 08:35pm 13 Oct 2020
  TweakerRay said  I checked also some .mod files (for instance in the wolfenstein demo is a folder with .mod files... some play and one will crash my machine: called "alieni_vol_1.mod"
This is strange behavior, this MOD always played well here. All MODs that I use in my games I edit them on the OpenMPT and save as protracker format, including with limited frequency to the Amiga standard.
Posted: 09:59pm 13 Oct 2020
It's as if Execute with Run doesn't fully initialise things and so eventually crashes with something like a stack overflow.
Posted: 07:21am 14 Oct 2020
Not easily solvable - the issue is stack overflow. Playing MP3 just happens to hammer the stack. You will have to put a counter in your program (VAR SAVE) and get the user to re-run when the counter expires.
> list "zero.bas"
var clear
> list "one.bas"
var restore
Print "One"
print a,hex$(mm.info(stack))
a=a+1
if a=5 then end
var save a
Pause 5000
> list "two.bas"
Print "Two"
Pause 500
Edited 2020-10-14 17:30 by matherp
Posted: 08:50am 14 Oct 2020
OK ignore the above - had a brainwave - try the attached
CMM2V1.5.zip
Hi Peter,
  matherp said  Not easily solvable - the issue is stack overflow. Playing MP3 just happens to hammer the stack...
I dearly hope this is one of those occasions where you go off back to your shed and 4 hours (or less) later have fixed the problem.
As it is (except for the workaround I have provided below) this excludes any application where multiple programs cooperate to achieve a result, including any sort of shell program (GUI or command line) unless all its applications are built into the shell itself. Note even with this issue fixed the applications still have to know they were launched by, and return control to the shell ... unless we get something built into the firmware at a later date to facilitate this - I AM NOT ASKING NOW - first write the shell, then hassle the firmware guru.
From a position of complete ignorance (and thus probably "talking sh*t") I am guessing at the moment that when you have to act on an EXECUTE "RUN ..." you "perform X" to start the new program. Would an alternative be to set a flag, unwind (as if encountering an END) and then if the flag is set then "perform X" ?
  Quote  You will have to put a counter in your program (VAR SAVE) and get the user to re-run when the counter expires.
That doesn't even qualify as a bad workaround
For the moment I'm back to doing this as suggested by @TassyJim many months ago before EXECUTE was added to the firmware:
> list "one.bas"
Print "One"
Print "Stack = " + Hex$(Mm.Info(STACK))
Pause 50
Open "/run.tmp" For Output As #1
Print #1, "Run " + Chr$(34) + "Two" + Chr$(34)
Close #1
Run "/run.tmp"
> list "two.bas"
Print "Two"
Pause 10
Print #1, "Run " + Chr$(34) + "One" + Chr$(34)
Close #1
Run "/run.tmp"
Posted: 08:53am 14 Oct 2020
  matherp said  OK ignore the above - had a brainwave - try the attached
CMM2V1.5.zip
You make a rod for your own back my friend, I will go and fire up the Windows box.
Cheers,
Posted: 09:11am 14 Oct 2020
THAT FIXED IT
You're "the man" Peter, thank you.
Back to the "code mines" for me,
Edited 2020-10-14 19:15 by thwill
TweakerRay
Posted: 05:11pm 14 Oct 2020
I checked the welcome tape a little... what I found is that the pirate game had
a missing characters of the written text on the left side.
didn't you want to use the polysynth programm ? Have not seen that.
and no music on the beginning ... i may have the wrong file ? Where can i download the latest version ?
Posted: 05:44pm 14 Oct 2020
Hi TR,
  TweakerRay said  I checked the welcome tape a little... what I found is that the pirate game had a missing characters of the written text on the left side.
I suspect your monitor is not properly adjusted for the mode that it uses. There may be an auto adjust feature on your monitor and/or manual hpos and vpos conttol
  Quote  didn't you want to use the polysynth programm ? Have not seen that.
There was a download link for an alpha version in the same email where I pointed you at the experimental firmware. Polysynth is included but I haven't fully integrated it with the menu yet.
Edited 2020-10-15 03:55 by thwill
TweakerRay
Posted: 07:05pm 14 Oct 2020
nope the screen was centered... and I had big borders around... so not screen problem of my tv...
I also have just tried to play a few mp3... a big mp3 with 12 mb which played a long time ago did not work... a different one worked and the spaceflight music did stuck and did work some times and sometime not... I suspect that the mp3 player from the color maximite might have problems with integrated coverimages ? Because they are in the header of the file and I just erased the coverartwork (which is sad since I think its cool to have that in the mp3) but I guess this might confuse the player... I try that out a little more... but I guess I am on a right track... also the tags which are in the mp3 might be a problem ? But I guess its the artwork... its a jpg which is in the mp3 so this might cause the problem.
TweakerRay
Posted: 07:09pm 14 Oct 2020
yep its the coverartwork... after i erased it out of the mp3 then the mp3 plays flawlessly in the commandline browser... this is unexspected since it worked before with the artwork. did something change in the player ? That now the artwork is a problem ?
