Forum Index : Microcontroller and PC projects : CMM2: Sprite vs. background question
| epsilon Senior Member Joined: 30/07/2020 Location: BelgiumPosts: 255 |
Hi all, I don't fully understand how on CMM2 sprites work relative to the background. I'm in 8-bit mode. I have a sprite the size of a character. Here is the code fragment that confuses me: TEXT 0,0, "A" '1. Shows letter A in upper left corner DO WHILE INKEY$="":LOOP:DO WHILE INKEY$<>"":LOOP 'Wait for key press SPRITE SHOW 2, 0, 0, 2 '2. Shows sprite with letter A underneath. DO WHILE INKEY$="":LOOP:DO WHILE INKEY$<>"":LOOP 'Wait for key press TEXT 0,0, "V" '3. Show letter V in upper left corner DO WHILE INKEY$="":LOOP:DO WHILE INKEY$<>"":LOOP SPRITE SHOW 2, 0, 0, 2 '4. Show sprite with letter A underneath (why not V?) Step 3. The letter V overwrites the sprite. This shows that sprites don't live in a separate plane before or behind the background. They behave more like stickers that get pasted on the background. OK. Step 4 however I don't understand. I'm redisplaying the sprite here so I was expecting to see the sprite with the letter V underneath. Instead I see the letter A underneath. Where did that come from? Here is the full code: OPTION BASE 0 MODE 1, 8 FONT 1, 1 DIM CRSR_INS_SPRITE%(MM.INFO(FONTWIDTH)*MM.INFO(FONTHEIGHT)-1) CRSR_INS_SPRITE_DATA: DATA RGB(WHITE), RGB(WHITE), 0, 0, 0, 0 ,0 ,0 DATA RGB(WHITE), RGB(WHITE), 0, 0, 0, 0 ,0 ,0 DATA RGB(WHITE), RGB(WHITE), 0, 0, 0, 0 ,0 ,0 DATA RGB(WHITE), RGB(WHITE), 0, 0, 0, 0 ,0 ,0 DATA RGB(WHITE), RGB(WHITE), 0, 0, 0, 0 ,0 ,0 DATA RGB(WHITE), RGB(WHITE), 0, 0, 0, 0 ,0 ,0 DATA RGB(WHITE), RGB(WHITE), 0, 0, 0, 0 ,0 ,0 DATA RGB(WHITE), RGB(WHITE), 0, 0, 0, 0 ,0 ,0 DATA RGB(WHITE), RGB(WHITE), 0, 0, 0, 0 ,0 ,0 DATA RGB(WHITE), RGB(WHITE), 0, 0, 0, 0 ,0 ,0 DATA RGB(WHITE), RGB(WHITE), 0, 0, 0, 0 ,0 ,0 DATA RGB(WHITE), RGB(WHITE), 0, 0, 0, 0 ,0 ,0 SUB initInsSprite LOCAL ii% RESTORE CRSR_INS_SPRITE_DATA FOR ii%=0 TO MM.INFO(FONTWIDTH)*MM.INFO(FONTHEIGHT)-1 READ CRSR_INS_SPRITE%(ii%) NEXT ii% END SUB initInsSprite SPRITE LOADARRAY 2, MM.INFO(FONTWIDTH), MM.INFO(FONTHEIGHT), CRSR_INS_SPRITE%() TEXT 0,0, "A" DO WHILE INKEY$="":LOOP:DO WHILE INKEY$<>"":LOOP SPRITE SHOW 2, 0, 0, 2 DO WHILE INKEY$="":LOOP:DO WHILE INKEY$<>"":LOOP TEXT 0,0, "V" DO WHILE INKEY$="":LOOP:DO WHILE INKEY$<>"":LOOP SPRITE SHOW 2, 0, 0, 2 Thanks for any help, Ruben/Epsilon Epsilon CMM2 projects |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12085 |
Sprites are implemented in S/W. When you first display a sprite it saves the background where it will be displayed and then overwrites it. When you move a sprite it restores the stored background in the old position, stores the background in the new position and then writes out the sprite. If you need to write to the screen with non-sprite commands you must hide any sprites that may be overwritten first and then restore them after the non-sprite write. An alternative is to write the sprites to a cleared to black page and then blit that page with transparency to the page on which you are using non-sprite writes. Another alternative is to use 12-bit mode. Have the sprites on page 1 and everything else on page 0 Edited 2020-10-13 19:47 by matherp |
Thank you for the quick response! So this works fine: TEXT 0,0, "A" DO WHILE INKEY$="":LOOP:DO WHILE INKEY$<>"":LOOP SPRITE SHOW 2, 0, 0, 2 DO WHILE INKEY$="":LOOP:DO WHILE INKEY$<>"":LOOP SPRITE HIDE 2 'Hide sprite because it will be overwritten. TEXT 0,0, "V" DO WHILE INKEY$="":LOOP:DO WHILE INKEY$<>"":LOOP SPRITE SHOW 2, 0, 0, 2 'Redisplay sprite Got it. So sprites don't automatically live on a separate 'plane', but you can still make it so. Cool! Epsilon CMM2 projects |
I ran into a subtle issue with BLIT which manifests itself as an 'incorrect sprite background' issue, which started this thread. Here is a code snippet that triggers the issue: SPRITE LOADARRAY 2, 8, 12, CRSR_INS_SPRITE%() DIM s0$ = "'--> Key Codes. Press Alt-K in the editor to see the keycode corresponding to a keypress. Combos with Ctrl, Shift and Alt are supported. " DIM s1$ = "'CONST FG_COLOR% = RGB(230, 230, 230)" PAGE WRITE 4 CLS TEXT 8, 12, MID$(s0$, 1, 98) PAGE WRITE 0 CLS TEXT 8, 12, MID$(s0$, 1, 98) SPRITE SHOW 2, 98*8, 12, 1, 0 DO WHILE INKEY$="":LOOP:DO WHILE INKEY$<>"":LOOP SPRITE HIDE 2 DO WHILE INKEY$="":LOOP:DO WHILE INKEY$<>"":LOOP TEXT 8, 12, MID$(s0$, 40, 98) BLIT 8, 24, 8, 24, 0, 12, 4 DO WHILE INKEY$="":LOOP:DO WHILE INKEY$<>"":LOOP SPRITE SHOW 2, 98*8, 12, 1, 0 So, in a nutshell: 1. I print a line of text and overlay a cursor shaped sprite. 2. I hide the sprite. 3. I modify the line of text. 4. I do a blit to a different part of the screen. 5. I redisplay the cursor shaped sprite. The redisplayed sprite in step 5 now has an incorrect background. It looks as if I forgot to hide the sprite in step 2. The issue is triggered by the funny BLIT in step 4. This BLIT has a width of 0. You might just say "don't do that" and move on. My workaround is of course to protect the BLIT with an 'if width > 0...' (in my actual code, the BLIT parameters are the result of a computation obviously). However, I have two issues with this: 1. I now have to 'special case' an otherwise linear sequence of code. But more importantly: 2. BLIT doesn't flag a width of 0 as invalid. The BLIT proceeds as expected. It's only later, in a different part of the graphics subsystem (sprites) that an issue appears, which makes it very hard to track down the problem. I have attached the complete test program. Cheers, Ruben/Epsilon. xdbg.zip Epsilon CMM2 projects |
What version? - the code suggests this is fixed in RC21 |
This is still 5.05.05. I haven't been brave enough to jump on the early adapter beta FW bandwagon. The problem is that the program I'm writing and debugging is itself in alpha/beta stage and I'm just not looking forward to testing and debugging my alpha SW on beta FW. Great to hear that this issue will be fixed in the next FW release however! Epsilon CMM2 projects |
| RetroJoe Senior Member Joined: 06/08/2020 Location: CanadaPosts: 290 |
Ruben, Just curious - why the DO:INKEY:LOOP twice? Shouldn’t once be enough? FYI, I went the other way i.e. towards the bleeding edge. Now, I think the springy things on my programming jumper block are wearing out from the daily firmware updates! BTW, I distinctly remember (and it’s here on TBS somewhere...) Peter saying the CMM2 FW was feature complete, and no updates other than for bug fixes ;) Cheers, and keep up the great work! Enjoy Every Sandwich / Joe P. |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1784 |
It is not the same twice! DO WHILE INKEY$="":LOOP:DO WHILE INKEY$<>"":LOOP The first loop stops as long as no key is pressed. The second loop stops while a key is pressed. Regards Michael Edited 2020-11-19 01:16 by twofingers |
| jirsoft Guru Joined: 18/09/2020 Location: Czech RepublicPosts: 533 |
I'm using it same way to prohibit "stuck" keys (but anyways it sometimes doesn't help...). Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), Â CMM2.fun |
Exactly. The idea is to require a key press and a key release before moving on to the next statement. For a very sensitive function like KEYDOWN additional debouncing might be needed. INKEY$ isn't that sensitive however so the above combo should be good enough, for a quick test program at least. Epsilon CMM2 projects |
Thanks - I missed the debouncing logic. Very nice! Enjoy Every Sandwich / Joe P. |
