Author
Message
William Leue Guru Joined: 03/07/2020 Location: United StatesPosts: 411
Posted: 08:07pm 10 Oct 2020
I am getting "Error: Dimensions" when I try to use this option default integer option base 1 dim Stuff(12, 4, 2, 5, 3) This is only 1440 integer values, surely not too large. According to the docs, MMBasic is supposed to support arrays with 5 dimensions. The firmware version is 5.05.05 Any clues? -Bill
twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1784
Posted: 10:16pm 10 Oct 2020
Hi Bill, IMHO you found your first BUG! Congratulation! With "Option Base 1" I get the mysterious error even for DIM Stuff(1) - after I executed your code -, but not always reproducible. Strange! I get an error for this:_option default integer option base 1 dim integer test(1)
Without this both options:option default integer option base 1
I can execute DIM stuff(1200,4,2,5)
without an issue, but DIM stuff(12,4,2,5,0) results in an (Dimension) error. I have never encountered problems related to DIM in the past. MMBasic CMM2_Beta - V5.05.06RC2 MichaelEdited 2020-10-11 08:31 by twofingers
Posted: 10:49pm 10 Oct 2020
Ok well I'm glad it's not just some idiot mistake of mine. I'll be interested in hearing Peter's take on this. -Bill
mkopack73 Senior Member Joined: 03/07/2020 Location: United StatesPosts: 261
Posted: 01:56am 11 Oct 2020
twofingers said Hi Bill, IMHO you found your first BUG! Congratulation! With "Option Base 1" I get the mysterious error even for DIM Stuff(1) - after I executed your code -, but not always reproducible. Strange! I get an error for this:_option default integer option base 1 dim integer test(1)
without an issue, but DIM stuff(12,4,2,5,0) results in an (Dimension) error. I have never encountered problems related to DIM in the past. MMBasic CMM2_Beta - V5.05.06RC2 Michael Ok, well, just a shot in the dark but: If you ARE using OPTION BASE 1, then a dimension of value of 1 isn't actually a dimension - it's a single cell. Without OPTION BASE 1 (ie BASE 0), then setting the value to 0 is again setting it to a single value which isn't an array then... However, that doesn't explain why the OP's code didn't work.
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12087
Posted: 07:58am 11 Oct 2020
Quote DIM stuff(12,4,2,5,0) results in an (Dimension) error. This looks like a day-1 MMBasic bug. Will liaise with Geoff and fix in next release Quote If you ARE using OPTION BASE 1, then a dimension of value of 1 isn't actually a dimension - it's a single cell. This correctly gives an error
