Local Time 21:45 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : TeraTerm / Output Redirection / Input oddities
elk1984
Posted: 07:12pm 10 Oct 2020
Using the CMM2 with a capture card and Tera Term effectively gives a two monitor setup which is very cool.
Is it possible to write output to the terminal window only? - this would be really useful for debug data for game development / graphics work.
On a different but related note, has anyone noticed oddities when pasting text into the program editor via Teraterm.  The first few characters work OK and single lines are fine, but carriage returns behave oddly - either being ignored, or characters after the carriage return corrupting the rest of the input stream.
Posted: 08:13pm 10 Oct 2020
OPTION CONSOLE SERIAL will disable the console output to the VGA screen and send all output to the serial console.
This is useful for debugging graphics applications as diagnostic PRINT statements will not corrupt the screen display.
In TeraTerm, try putting in a delay under setup/serial port/ msec/line
elk1984
Posted: 08:28pm 10 Oct 2020
  TassyJim said  OPTION CONSOLE SERIAL will disable the console output to the VGA screen and send all output to the serial console.
Thank you - perfect!
elk1984
Posted: 08:50pm 10 Oct 2020
Working with a few changes.  Transmit delay of 1ms/char, 500ms/line and New-line terminal transmit changed to CR+LF.
Just about quicker than popping the SD card out for smaller fragments of code.
Posted: 09:18pm 10 Oct 2020
500ms/line is way too slow
try 100 and scrap the character delay.
Edited 2020-10-11 07:19 by TassyJim
