Forum Index : Microcontroller and PC projects : ANN: CircuitGizmos RetroMax
Since the Polish (not Russian) version was posted, I should post the CG version. Was planning on doing this tomorrow... CircuitGizmos RetroMax ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Micromites and Maximites! - Beginning Maximite |
Some features of the RetroMax: - Compatibility with the Color Maximite 2 (different enclosure, board layout, but functionally the same) The RetroMax is designed to be simple and fun. This CircuitGizmos RetroMax is functionally the same as the Color Maximite 2 version from magazine articles and sold previously here, except there are some changes and additions: - Different board shape/size appropriate for the optional enclosure - Board mounting holes for VESA 100mm back-of-monitor mounting - Power button that toggles on/off - Reset available from front panel - IR receiver behind translucent window (on case) - Micro SD card holder - Firmware reflash button available on side - Additional "User LED" in white - Piezo "User Buzzer" - Two Nunchuk connections for two game players - PCB connection for optional real-time clock - PCB sea-of-holes for user hardware, conducive to Arduino shields - Mounting holes and orientation for Raspberry Pi HATS Accessories included with the case purchase are a 20 inch power/console USB cable, reset key, and high impedance ear buds. Micromites and Maximites! - Beginning Maximite |
Looks nice. Obviously the MCU and RAM on the same side works fine. Good to know. Is the VGA socket through hole? Visit Vegipete's *Mite Library for cool programs. |
Thanks! Yes, the VGA socket is a through-hole part. I've has some serious issues with SMT VGA connectors. Micromites and Maximites! - Beginning Maximite |
| William Leue Guru Joined: 03/07/2020 Location: United StatesPosts: 411 |
Interesting! I am waiting to see whether the designer follows through on the idea of adding a mouse interface. If so, I am sold! -Bill |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10081 |
Love the VESA mount holes idea on your board. ![]() Perfect for turning an old VGA LCD monitor into a dedicated CMM2 system, minimizing the cables and clutter. The rest of the board also looks very nice indeed. I'm flattered by the silkscreen thank. ![]() Smoke makes things work. When the smoke gets out, it stops! |
