Local Time 09:04 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: If you want a mouse
     Page 1 of 4
Posted: 07:03pm 05 Oct 2020
Get one of these
The STM32H7 only supports a single USB device so I can't I/F a USB mouse. Serial and PS2 mice are getting hard to find so I/F a USB mouse. I'm sure there are other options out there but this is tested and works. Also available a a pre-programmed chip (much cheaper)
JoOngle
Posted: 07:11pm 05 Oct 2020
Interesting information Peter, (takes notes), this chip could be included on a future PCB.
Sasquatch
Posted: 07:38pm 05 Oct 2020
Thanks for the link!  I just ordered 3.  I have been looking for something to interface with devices that have a built-in FTDI USB-Serial interface etc.
-Carl
William Leue
Posted: 07:48pm 05 Oct 2020
Interesting! Thanks, Peter!
-Bill
elk1984
Posted: 07:54pm 05 Oct 2020
  matherp said  Get one of these
Thanks Peter, ordered.  I just need to understand where to interface it to get writing something to read it:-
https://www.hobbytronics.co.uk/usb-host-mouse
Edited 2020-10-06 06:40 by elk1984
Andrew_G
Posted: 09:56pm 05 Oct 2020
Hi all,
Does this mean we can retain the existing USB keyboard and add a USB joystick (and/or) mouse via something like this?
Cheers,
Andrew
Turbo46
Posted: 10:03pm 05 Oct 2020
This Does work for a mouse.
Edit and here
Edited 2020-10-06 08:15 by Turbo46
Andrew_G
Posted: 11:49pm 05 Oct 2020
Hi Bill, et al,
I have just read the SC article and it says
  Quote  Note that most of the mouses that we tried which had mouse wheels did not report mouse wheel rotation using the basic HID protocol, so it’s unlikely that you will be able to detect rotation of the mouse wheel using this Adaptor.
I'm not sure about the one that Peter identified?
An interesting thought on this device though - the chip is programmed differently depending on whether it is to be used for a mouse or a keyboard - could a jumper, or upfront INPUT, select which variant runs?
Again I'm not sure about the one that Peter identified?
Cheers,
Andrew
Turbo46
Posted: 12:47am 06 Oct 2020
  Quote  could a jumper, or upfront INPUT, select which variant runs?
You can download the C source for each variant so I would expect that they could be combined but that's way beyond me.
I posted a demo using that device on the CMM1 here.
Posted: 05:20am 06 Oct 2020
Another USB Host adapter on Banggood site. SPI interface.
Mini USB Host Shield 2.0 ADK SLR Development Tool
Brand: LILYGO
Posted: 06:59am 06 Oct 2020
  Quote  'm not sure about the one that Peter identified?
  Quote   The comma delimited output looks like the following
X,Y,LB,RB,SB,XS,YS,SS
Where
  X - X Virtual Screen Pos
  Y - Y Virtual Screen Pos
 LB - Left Button
 RB - Right Button
 SB - Scroll Wheel Button
 XS - X mouse scroll (move) value
 YS - Y Mouse Scroll (move) value
 SS - Scroll Wheel scroll value
Posted: 10:52am 06 Oct 2020
Test code. There does seem to be an issue with the scroll wheel. It works but seems to continue counting unless the mouse moves. I've written to Hobbytronic to ask why
initmouse
sprite load "mouse.spr",1
do
 readmouse
 sprite show 1,x,y,1
 text 0,0,str$(x,6,0," ")+str$(y,6,0," ")+str$(lb,2,0," ")+str$(rb,2,0," ")+str$(sb,2,0," ")+str$(xs,4,0," ")+str$(ys,4,0," ")+str$(ss,6,0," ")
 pause 10
loop
sub initmouse
 i2c open 100,1000
 i2c write 41,0,3,20,int(mm.hres \ 256),int(mm.hres mod 256)
 i2c write 41,0,3,22,int(mm.vres \ 256),int(mm.vres mod 256)
 i2c write 41,0,3,24,int(mm.hres \ 512),int((mm.hres\2) mod 256)
 i2c write 41,0,3,26,int(mm.vres \ 512),int((mm.vres\2) mod 256)
 i2c write 41,0,2,28,10
end sub
sub readmouse
 do
   i2c write 41,1,1,0
   i2c read 41,0,10,s$
   x=str2bin(uint16,left$(s$,2),big)
   y=str2bin(uint16,mid$(s$,3,2),big)
   lb=asc(mid$(s$,5,1))
   rb=asc(mid$(s$,6,1))
   sb=asc(mid$(s$,7,1))
   xs=str2bin(int8,mid$(s$,8,1))
   ys=str2bin(int8,mid$(s$,9,1))
   ss=ss+str2bin(int8,mid$(s$,10,1))
 loop until x>=0 and x<MM.hres and y>=0 and y< mm.vres 'trap missreads
end sub
Mouse.spr
13,1,19
7
77
7 7
7  7
7   7
7    7
7     7
7      7
7       7
7        7
7         7
7          7
7      777777
7   7  7
7  77  7
7 7  7  7
77   7  7
     7  7
     7777
Posted: 02:47pm 06 Oct 2020
I like the Silicon Chip model from January 2019, but the unit that matherp linked to at the very top of this thread is a nice unit also.  The pre-programmed chip in SOIC or SSOP is only US$7 each, which is a pretty sweet-spot price wise.
The SSOP and PDIP packages are in stock at Microchip Direct and cost about US$3.50 each, and then you could just upload the firmware to the chip yourself if you wanted to keep the costs to an absolute minimum.  The SOIC and QFN packages are out of stock.
Very affordable device though.  Might have to add some of these to my next order from Microchip Direct.
I am particularly interested in the USB 3G Modem version of the firmware, which allows you to take a USB GSM modem stick thing, to simplify sending and receiving text messages.  The supported USB modem sticks are about US$20 on eBay or AliExpress, which is half the price of the SimCom modules I am using at the moment, and have to fight them every step of the way to make them work.  Might have to get one of those USB sticks in and play with that firmware first!
Posted: 03:17pm 06 Oct 2020
  Quote  The SSOP and PDIP packages are in stock at Microchip Direct and cost about US$3.50 each, and then you could just upload the firmware to the chip yourself if you wanted to keep the costs to an absolute minimum.  The SOIC and QFN packages are out of stock.
No you can't. It relies on a pre-programmed bootloader which is copy protected
Edited 2020-10-07 01:18 by matherp
Posted: 03:38pm 06 Oct 2020
Damn.
Oh well.  I just won't order from Microchip Direct then - good to know that ahead of time.
I will just get some pre-programmed chips from HT then and be done with it.  Quite keen to try out the USB GSM modem one.
elk1984
Posted: 07:12pm 07 Oct 2020
Great recommendation and Hobbytronics are really fast.  Just arrived today!
Trouble is, I'm a total wiring newbie.  I'm guessing there's different ways of wiring this depending on what protocol you want to read?  I'm assuming it doesn't need both 5V and 3.3V power simultaneously.
USB Host   - CMM2 GPIO
5V         - Pin 2 (5V Power)
0V         - Pin 6 (Ground)
3V3        - Pin 1 (3.3V Power)
SDA / SDI  - Pin 3 (I2C SDA)
SCL / SCK  - Pin 5 (I2C SCK)
A / SDO    - Pin 12 (PWM 1A) ?
SS         - ?
RX         - PIN 10 (COM1 RX)
TX         - PIN 8  (COM1 RX)
Posted: 08:35pm 07 Oct 2020
You don't need both 5V and 3.3V
There is an onboard 3.3V regulator. - Check the supplied schematic.
You do need 5V to supply the 5V on the USB connector so use 5V and ignore the 3.3V
You use either I2C or Serial. You don't need both and the choice is yours.
Serial is easier to start with.
elk1984
Posted: 08:44pm 07 Oct 2020
  TassyJim said  You don't need both 5V and 3.3V
Thanks Jim.  So this one basically?   (Reading a schematic isn't something I'm up to - any electronics 101 suggestions welcome)
0V         - Pin 6 (Ground)
Edited 2020-10-08 06:50 by elk1984
Posted: 08:59pm 07 Oct 2020
You need to swap (cross-over) the RX and TX
One side transmits to the receiver on the other side.
0V         - Pin 6 (Ground)
RX         - PIN 8 (COM1 TX)
TX         - PIN 10 (COM1 RX)
elk1984
Posted: 09:01pm 07 Oct 2020
  TassyJim said  You need to swap (cross-over) the RX and TX
0V         - Pin 6 (Ground)
Thanks - doh I did say I'm a total wiring newbie
     Page 1 of 4
