Local Time 22:57 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Thank you
pitrz
Posted: 06:51pm 05 Oct 2020
Hi guys,
just finished building CMM2 and had a blast doing it. What a neat project and the software is great!
Only problem I had during the build: Had to de-solder and purchase a new SD card socket. The card detect and write detect pins are very close to the shield (for my soldering skills). I got a tiny teeny bit of solder under the socket/pin which somehow was touching the shield. Had to remove the whole socket and damaged it in the process.
Thanks again! Had so much fun and much more to come!
P.
JoOngle
Posted: 07:12pm 05 Oct 2020
Congratulations on your build, and welcome to the forum :)
Posted: 02:02am 06 Oct 2020
My congratulation also.  Welcome to the club.
Yes, the CD and WP sensor pins are VERY close to the shield on that socket, and it is very, very easy to accidentally bridge to the shield.  I use the finest solder I can find in my workshop for doing those two pins, so that you have much more control over the amount of solder that is flowing.  I use 0.38mm solder for those pins, and plenty of flux.
