Forum Index : Microcontroller and PC projects : CMM2 ERROR: SYSTEM FAULT - CHECK CODE
Chopperp![]() Guru Joined: 03/01/2018 Location: AustraliaPosts: 1139 |
Hi, Up till recently, if I got an error, the line number etc would display & also the line number would be indicated when F4 on the console was pressed to bring up the program. Now, on an error, I get a blank screen with the message CMM2 ERROR: SYSTEM FAULT - CHECK CODE. Initially thought that there was no obvious indication as to where or what the fault was. Printing MM.ERRRNO just said 0 I ended up recording the screen & eventually found that the original message referring to fault in the line number briefly flashed up & then the screen went blank with the ERROR: etc message showing. First time it happened was with an out of bounds array & the latest one was an inadvertent space in a variable. Running b14 Any ideas? May or may not be related, but I'm getting an XMODEM Syntax error if I try to Load & Run current code from within MMEdit. I can transfer the file to the CMM2 with MM File OK although the CMM2's files aren't being listed. I may just need to reload MMEdit. Brian ChopperP |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12088 |
Please update to b17. These are betas and some were more beta than others |
OK. Will advise tomorrow Thanks ChopperP |
Double post?? Edited 2020-10-04 23:27 by Chopperp ChopperP |
OK, b17 fixed the error messages. XMODEM still not OK. May be one for Jim. Thanks ChopperP |
Make sure that MMEdit is set to be talking to a CMM2. Micromites and Maximites! - Beginning Maximite |
Dah, Thanks CG, that fixed it. Works when set to CMM2. Forgot about that setting. Must have inadvertently changed it. CMM2 going great BTW Edited 2020-10-05 08:04 by Chopperp ChopperP |
![]() Micromites and Maximites! - Beginning Maximite |
