Local Time 22:58 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Elite rotating ship demo
PeteCotton
Posted: 05:30am 03 Oct 2020
After the discussion about the speed of the maximite rotating and drawing the ships from Elite, I decided to do a little field test.
So here we have the fully shaded Cobra Mk III (of course) spinning at about 130 to 160 frames per second.
Note: This is not meant to be an indicator of the speed you would get of it in game with everything else going on, and it hasn't been tuned in any way, I am sure we could get the speed up significantly. It was just a mental excersise to answer the questions we all had.
https://youtu.be/m4g4RJX742o
PeteCotton
Posted: 05:32am 03 Oct 2020
Source code here:
RotateTest.zip
dim vertex(11,3)   ' Store 11 vertex points of x, y and z co-ordinates
dim nodeCount%=11
dim plane(16,4)   ' Planes are made up of 3 or 4 vertexes
dim drawNodeX(16)  ' Stores the translated X,Y,Z co-ords of each node/vertex
dim drawNodeY(16)
dim drawNodeZ(16)
dim polyX(4)       ' The array we use to store the 4 points of the polygon
dim polyY(4)
' Vertex data is stored in 2 dimensional array where the 2nd dimension defines x, y or z
vertex(0,0)=32:vertex(0,1)=0:vertex(0,2)=76
vertex(1,0)=-32:vertex(1,1)=0:vertex(1,2)=76
vertex(2,0)=0:vertex(2,1)=26:vertex(2,2)=24
vertex(3,0)=-120:vertex(3,1)=-3:vertex(3,2)=-8
vertex(4,0)=120:vertex(4,1)=-3:vertex(4,2)=-8
vertex(5,0)=-88:vertex(5,1)=16:vertex(5,2)=-40
vertex(6,0)=88:vertex(6,1)=16:vertex(6,2)=-40
vertex(7,0)=128:vertex(7,1)=-8:vertex(7,2)=-40
vertex(8,0)=-128:vertex(8,1)=-8:vertex(8,2)=-40
vertex(9,0)=0:vertex(9,1)=26:vertex(9,2)=-40
vertex(10,0)=-32:vertex(10,1)=-24:vertex(10,2)=-40
vertex(11,0)=32:vertex(11,1)=-24:vertex(11,2)=-40
plane(0,0)=2:plane(0,1)=1:plane(0,2)=0
plane(1,0)=0:plane(1,1)=1:plane(1,2)=10:plane(1,3)=11
plane(2,0)=6:plane(2,1)=2:plane(2,2)=0
plane(3,0)=0:plane(3,1)=4:plane(3,2)=6
plane(4,0)=7:plane(4,1)=4:plane(4,2)=0:plane(4,3)=11
plane(5,0)=1:plane(5,1)=2:plane(5,2)=5
plane(6,0)=5:plane(6,1)=3:plane(6,2)=1
plane(7,0)=1:plane(7,1)=3:plane(7,2)=8:plane(7,3)=10
plane(8,0)=9:plane(8,1)=5:plane(8,2)=2
plane(9,0)=2:plane(9,1)=6:plane(9,2)=9
plane(10,0)=3:plane(10,1)=5:plane(10,2)=8
plane(11,0)=7:plane(11,1)=6:plane(11,2)=4
plane(12,0)=10:plane(12,1)=8:plane(12,2)=5
plane(13,0)=11:plane(13,1)=7:plane(13,2)=4
plane(14,0)=9:plane(14,1)=10:plane(14,2)=8:plane(14,3)=5
plane(15,0)=9:plane(15,1)=6:plane(15,2)=7:plane(15,3)=11
plane(16,0)=9:plane(16,1)=11:plane(16,2)=10
sub rotate(ax, ay, az)
  snz=sin(az)
  csz=cos(az)
  sny=sin(ay)
  csy=cos(ay)
  snx=sin(ax)
  csx=cos(ax)
  for n=0 to nodeCount%
    x=vertex(n,0)  'x
    y=vertex(n,1)  'y
    ' Rotate around z
    drawNodeX(n)=x*csz-y*snz
    drawNodeY(n)=y*csz+x*snz
    drawNodeZ(n)=vertex(n,2)  'z
    ' Rotate around y
    x=drawNodeX(n)
    z=drawNodeZ(n)
    drawNodeX(n)=x*csy+z*sny
    drawNodeZ(n)=z*csy-x*sny
    ' Rotate around x
    y=drawNodeY(n)
    z=drawNodeZ(n)
    drawNodeY(n)=y*csx-z*snx
    drawNodeZ(n)=z*csx+y*snx
  next n
end sub
anglex=0:angley=0:anglez=0
'Main loop
do
 tts=timer
 page write 1
 cls
 anglex=anglex-0.00005
 angley=angley+0.01
 anglez=anglez+0.025
 rotate(anglex,angley,anglez)
 tt2=timer
 for v=0 to 16
   p1=plane(v,0)
   p2=plane(v,1)
   p3=plane(v,2)
   p4=plane(v,3)
   x1=drawNodeX(p1)
   y1=drawNodeY(p1)
'    z1=drawNodeZ(p1)
   x2=drawNodeX(p2)
   y2=drawNodeY(p2)
'    z2=drawNodeZ(p2)
   x3=drawNodeX(p3)
   y3=drawNodeY(p3)
'    z3=drawNodeZ(p3)
   dx1=x1-x2
   dy1=y1-y2
   dx2=x1-x3
   dy2=y1-y3
'    crossX=y1*z2-z1*y2
'    crossY=z1*x2-x1*z2
   crossZ=dx1*dy2-dy1*dx2
'   norm=sqr(crossx*crossx+crossy*crossy+crossz*crossz)
'   lightLevel=128+ (127*(crossY/norm))
   'dotproduct=x1*x2+y1*y2+drawNodeZ(p1)*drawNodez(p2)
   if crossZ>0 then
     if p4=0 then
       triangle 400+x1,300+y1,400+x2,300+y2,400+x3,300+y3,rgb(0,0,0), rgb(128+v*5,255,255)
     else   'It's a 4 point plane
       x4=drawNodeX(p4)
       y4=drawNodeY(p4)
       polyX(0)=x1+400
       polyY(0)=y1+300
       polyX(1)=x2+400
       polyY(1)=y2+300
       polyX(2)=x3+400
       polyY(2)=y3+300
       polyX(3)=x4+400
       polyY(3)=y4+300
       polygon 4,polyx(), polyy(),rgb(0,0,0),rgb(128+v*5,255,255)
     endif
   endif
 next v
 timerTotal=timer-tts
 timerRotate=tt2-tts
 timerDraw=timer-tt2
 fps=fps*0.9+0.1*(1000/timerTotal)
 print "FPS: " +str$(fps)
 print "Rotate: " + str$(timerRotate) +" ms"
 print "Draw: " + str$(timerDraw) + " ms"
 page copy 1,0
loop
PeteCotton
Posted: 05:44am 03 Oct 2020
For those interested, I got the cobra III dimensions from here:
http://www.elitehomepage.org/archive/
Posted: 07:22am 03 Oct 2020
JoOngle
Posted: 02:46pm 04 Oct 2020
Nice, well done!
elk1984
Posted: 05:51pm 04 Oct 2020
  PeteCotton said  After the discussion about the speed of the maximite rotating and drawing the ships from Elite, I decided to do a little field test.
Really, really nice!
TweakerRay
Posted: 09:34pm 05 Oct 2020
Hi Pete, Sorry to write into this,
I dropped you a message here, but I am not sure if you see this so I try here.
I have composed a music for your game, maybe you like to use that ?
Drop me your mailadress and I could send you the music.
Cheers TweakerRay
http://tweakerray.bandcamp.com
PeteCotton
Posted: 10:33pm 05 Oct 2020
  TweakerRay said  Hi Pete, Sorry to write into this,
Cheers TweakerRay
Thanks Ray. I din't realise there was a messenger facility on this forum (I see it now). Will respond right away!
MauroXavier
Posted: 12:00pm 06 Oct 2020
Cheers TweakerRay
GOD, thanks to you I have remembered me about this forum resource... I have many messages too from MONTHS AGO that I not answered... Shame on me!
