Local Time 00:12 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM2: Select Case vs CPU Restart...
Posted: 12:27pm 28 Sep 2020
Hi all.
MMBASIC 5.04.08
SELECT CASE CODE
 CASE ONE
 CASE ELSE
   CPU RESTART
END SELECT
The CPU RESTART command is never executed.
The work-around is easy enough:
SELECT CASE CODE
 CASE ONE
 CASE ELSE
   Y=1
END SELECT
IF Y THEN CPU RESTART
...but why does the first code example not work?
There are newer versions of MMBASIC then 5.04.08 now, so perhaps it has been addressed already.  I have a fix for it as shown above, but I am curious as to why the first version won't work.
Posted: 02:31pm 28 Sep 2020
That just does not seem right.  I am not near any hardware at this time so I cannot test it but the ELSE part of the SELECT command works perfectly and also CPU RESTART works perfectly.  I cannot see why the two together will not work.
I don't think that the version could be the issue as nothing has changed in this area since 5.04.08.
Could you please recheck this, it could be something in your test setup.
CircuitGizmos
Posted: 04:00pm 28 Sep 2020
Put some PRINTs around the CPU RESTART
PRINT "before"
CPU RESTART
PRINT "after"
panky
Posted: 12:56am 29 Sep 2020
@grogster
Not sure I understand your code, but
  Quote  MMBASIC 5.04.08
SELECT CASE CODE
CASE ONE
CASE ELSE
  CPU RESTART
END SELECT
..your SELECT CASE is based on the variable CODE, but your CASE statement is using the value in variable(or constant) ONE, in which case there is no relationship for any of the CASE statements to evaluate.
If you change your program to this, it works (version 5.05.06)
CODE = 1
SELECT CASE CODE
 CASE 1
   PRINT "CASE 1 WITH CODE  = 1"
 CASE ELSE
   PRINT "CASE ELSE"
   PAUSE 2000
END SELECT
PRINT " now try the else route"
PAUSE 2000
CODE = 99
SELECT CASE CODE
 CASE 1
   PRINT "CASE 1 WITH CODE = 99 - DOESN'T HAPPEN"
 CASE ELSE
   PRINT "CASE ELSE - HAPPENING!"
   PAUSE 2000
   CPU RESTART
END SELECT
The pause statements are in there so you can see what is happening.
Doug.
Posted: 02:10am 29 Sep 2020
Original code is working now.  Perhaps it was just that the chip got a bit upset with lots of download and test cycles, without cycling the power?
Came back today, put the code back as it was originally, and it is working fine.
@ panky: Yes, I am working on the SELECT CASE part of the code now.  In the example, there was nothing for the select case to evaluate as you say, so it was just supposed to simply CPU RESTART as CODE had not had the routines defined yet.  The "..." lines just mean lines of my code, which I omitted as they were not relevant to the issue, cos I was only wanting to make sure the the CASE ELSE took effect on any OTHER key-press then one of the valid ones - which are being defined in the CASE's now.
CODE is returned by the IR remote-control receiver interrupt, and SELECT CASE decides which button was pressed, but not all of them are used, so I wanted the system to just restart on any non-valid button press.
It is working now, which is odd, but perhaps it was just that cos I did so many program-new-program cycles on the chip last night(was up to 2AM) without ever cycling the main power, that something got a little upset?  Possible?
Posted: 09:05am 29 Sep 2020
  Grogster said  Perhaps it was just that the chip got a bit upset with lots of download and test cycles, without cycling the power?
No (sorry).  Everytime you load/edit/run a program MMBasic completely resets itself.  Also, it could not be a stray gamma ray flipping a bit as that would have crashed MMBasic.
Most likely it was a bug in your code which you did not notice and was not present when you reentered the test code... it happens to all of us - especially at 2AM.
Edited 2020-09-29 19:10 by Geoffg
Tinine
Posted: 02:00pm 30 Sep 2020
@Grogster
Dunno why, Graeme but that logic just cracked me up:
This?
Or this?
Or this?
Oh f**k it!
