Forum Index : Microcontroller and PC projects : Raspbian vs. Android
| hitsware2 Guru Joined: 03/08/2019 Location: United StatesPosts: 738 |
I have been seeking a sound card type oscilloscope for some time . I choose ( if possible ) to not use Windows . I have looked for a Raspberry Pi version to no avail . I now find that there are many that will run on an inexpensive Android T . V . box . Why the differance ? my site |
| robert.rozee Guru Joined: 31/12/2012 Location: New ZealandPosts: 2554 |
a popular choice is sigrok: https://sigrok.org/ this is open-source and can be compiled for all the major platforms (win32, linux, osx, android). i feel it should operate with a sound card, but a quick look didn't produce any useful info. but it can be used with one of these: https://www.aliexpress.com/item/810383099.html RPi vs android: both are linux under the hood. RPi has desktop optimized for the lower computing resources available, or you can run more standard distros. android is a 'google-a-fied' version of linux with a layer on top to simplify the UI and steer you towards using the google software store, but with a little hacking around you can sidestep most of this. cheers, rob :-) |
| Tinine Guru Joined: 30/03/2016 Location: United KingdomPosts: 1646 |
Android rocks! The same way that MMBASIC is our secret weapon for MCUs, RFO BASIC is the same for Android. Couple them together and nothings beats it |
