Local Time 19:44 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Mr. Polysynth
TweakerRay
Posted: 09:19pm 27 Sep 2020
Hi !
I made somehow a musical keyboard and named it Mr. Polysynth -
you can play up to 4 notes. Change octaves and so on...
It's not perfect but I think I made progress in programming ;-)
Mr-Polysynth.zip
And the Monoversion:
Mr-Monosynth.zip
(And maybe you missed my Drumsynth Programm)
DrummachineV10.zip
Cheers ;-)
Edited 2020-09-28 07:22 by TweakerRay
http://tweakerray.bandcamp.com
Posted: 11:23am 01 Oct 2020
Hey "TweakerRay",
I know our last interaction was unproductive, but I was wondering if we could put that aside and ask you:
1) Do you think Mr-Polysynth might be suitable for inclusion on the "Welcome Tape" licensed under the MIT License
   - I also wondered whether it might be possible to display the musical stave at the same time reusing some of Bill's work: http://www.thebackshed.com/forum/ViewTopic.php?TID=12836
2) Do you have some pre-existing work that could be repurposed as the title screen soundtrack for PeteCotton's Defender clone which with some additional filing off of the serial numbers I'm proposing to include on the "Welcome Tape".
Edited 2020-10-01 21:31 by thwill
TweakerRay
Posted: 06:25pm 03 Oct 2020
Oh... Hi I just see this now @thwill -
Yes you can use Mr. Polysynth in the welcometape...I mean it's such a small community and if someone will make money with my programm then I am screwed... But I hope at least the people will see the original credits which are in that programm.
I am also working on another musical little helper programm... you could also use that too if you like Its a programm that plays the scale of a selected not and could randomly generate chord progressions from the selected scale... It's not finished yet but maybe you are interested in that too...
I sure have a music which could be used for the defender clone music...
Check this out: https://www.youtube.com/watch?v=c2rWBMTu-4Q
you could use this song as mp3 as long as I am credited as the musician
with correct credits...
If that is for interest let me give you the correct credits and then you can use this track...
Edited 2020-10-04 04:26 by TweakerRay
Posted: 09:27pm 03 Oct 2020
Thanks TweakerRay,
That's really generous of you and I will definitely check out all your programs for inclusion on the Welcome Tape.
That music is amazing, and very appropriate, assuming the game's author @PeteCotton is also fine with it I would love to try and use it. Can you post or PM me the credits and a link to obtain the track.
TweakerRay
Posted: 07:04am 04 Oct 2020
Hi !
The Credits would be
"Spaceflight" from the Album "Distance"
available for FREE download at http://tweakerray.bandcamp.com
composed by TweakerRay (www.tweakerray.de)
you can simply download the Album at my bandcamp page
https://tweakerray.bandcamp.com/album/tweakerray-distance-pay-as-much-as-you-like
it is a pay as much as you like album. But you can also just put in 0
and get all songs for free...
or you can just click the FREE single:
https://tweakerray.bandcamp.com/track/space-flight-free-download
Posted: 08:27pm 18 Oct 2020
Hi TR,
I've been "messing about" with Mr. Polysynth and kicking it into shape for inclusion on the "Welcome Tape" and I have some questions ... or possibly I have identified some bugs.
1. Does sine wave output s1,s2,s3,s4 = 2 (instead of the default 1) actually work for you ? ... it doesn't produce a tone for me.
2. In the key testing loop there is a variable named "switch" which is set when the keypress "tpress$" corresponds to one of the musical note keys ... however this is then tested outside the loop so when multiple keys are pressed simultaneously the test only passe if the last key depressed is a musical note key, i.e.
for i=1 to keydown(0) ' start of the key testing loop
  switch=0
  for x=28 to 44
    if tpress$=ta$(x) then switch=1
  next x
next i ' end of the key testing loop
' The value of switch here is the one for the last key tested
if switch=0 goto Screenstart
3. You maintain a variable "keys" which it looks like is supposed to be the number of musical note keys that are depressed, however when you then play the notes at the end of the main loop ...
If s1=1 and keys>0 then Play Sound 1,B,Q,freq1(tnr(1)+okt1)+tune1,volume
if s1=2 and Keys>0 then play Sound 1,B,S,freq1(tnr(1)+okt1)+tune1,volume
If s2=1 and keys>1 then Play Sound 2,B,Q,freq2(tnr(2)+okt2)+tune2,volume
if s2=2 and keys>1 then play Sound 2,B,S,freq2(tnr(2)+okt2)+tune2,volume
If s3=1 and keys>2 then Play Sound 3,B,Q,freq3(tnr(3)+okt3)+tune3,volume
if s3=2 and keys>2 then play Sound 3,B,S,freq3(tnr(3)+okt3)+tune3,volume
If s4=1 and keys>3 then Play Sound 4,B,Q,freq4(tnr(4)+okt4)+tune4,volume
if s4=2 and keys>3 then play Sound 4,B,S,freq4(tnr(4)+okt4)+tune4,volume
... I think this will produce the wrong result if for example 3 keys were depressed of which only keys 1 and 3 were musical, I think it will play tones 1 and 2 when it should play tones 1 and 3 shouldn't it?
TweakerRay
Posted: 08:24am 19 Oct 2020
When I tested last It worked for me... one did Square wave sound and the other did Sine when I rememeber that correctly. I will check that programm again ;-)
hmmm with that switching thing. I am not sure. Have to check. Will report as soon as I have checked that.
Cheers TweakerRay
Posted: 11:37am 20 Oct 2020
Hey TR,
In the interests of getting the next version of the "Welcome Tape" out I have taken the liberty of "messing about" with Mr. Polysynth. I hope you don't mind, I feel quite bad about the number of changes I've made:
' Mr. Polysynth
' Code by "TweakerRay"
' Messed about with for the CMM2 Welcome Tape by "thwill"
Option Explicit On
Option Base 1
'#Include "../../common/welcome.inc"
cls
color rgb(40,255,20)
?" Hi ! This is my small Polysynth V1"
?" You can play the synth with your keyboard:"
?" Just imagine the Keys from Q-P as White Keys and the numberkeys above as Black keys of a Piano"
?"  2  3        5  6  7     9  0     <----- Black Keys"
?" Q  W  E  R  T  Z  U  I  O  P      <----- White Keys"
?" The Synth can play up to 4 Notes simultaneously. All sounds come from both Speakers."
?" You can change the okaves on the 4 Notes independently:"
?" F1 / F2  Oktave up / down on Note 1"
?" F3 / F4  Oktave up / down on Note 2"
?" F5 / F6  Oktave up / down on Note 3"
?" F7 / F8  Oktave up / down on Note 4"
?" F9 / F10 Oktave up / down on ALL 4 Notes"
?" F11  Reset All oktaves to Zero   "
?" F12  Reset Tuning to Zero     "
?" Change the Sound on the Channel:"
?" A / S / D / F  -  Sound change + on Channel 1 / 2 / 3 / 4 (Square or Sine)"
?" Y / X / C / V  -  Sound change - on Channel 1 / 2 / 3 / 4 (Square or Sine)"
?" Detune Channels with:"
?" G / H / J / K  -  Detune + on Note 1 / 2 / 3 / 4"
?" B / N / M / ,  -  Detune - on Note 1 / 2 / 3 / 4"
?" Press [Esc] to Quit"
do while inkey$<>"" : loop
do while inkey$="" : loop
cls
dim freq(88)
dim i
dim k(4)
dim keys
dim layout$ = mm.info$(option usbkeyboard)
dim notes
dim okt(4)
dim s(4) ' 1=square, 2=sine, 3=noise
dim tnr(4) = (28,28,28,28) ' For if okt would be pressed before a key we set the key to C2
dim tune(4)
dim volume=12 ' Volume 1-25
freq(01)=27.5000 : freq(11)=48.9995 : freq(21)=87.3071 : freq(31)=155.563
freq(02)=29.1353 : freq(12)=51.9130 : freq(22)=92.4986 : freq(32)=164.814
freq(03)=30.8677 : freq(13)=55.0000 : freq(23)=97.9989 : freq(33)=174.614
freq(04)=32.7032 : freq(14)=58.2705 : freq(24)=103.826 : freq(34)=184.997
freq(05)=34.6479 : freq(15)=61.7354 : freq(25)=110.000 : freq(35)=195.998
freq(06)=36.7081 : freq(16)=65.4064 : freq(26)=116.541 : freq(36)=207.652
freq(07)=38.8909 : freq(17)=69.2957 : freq(27)=123.471 : freq(37)=220.000
freq(08)=41.2035 : freq(18)=73.4162 : freq(28)=130.813 : freq(38)=233.082
freq(09)=43.6536 : freq(19)=77.7817 : freq(29)=138.591 : freq(39)=246.942
freq(10)=46.2493 : freq(20)=82.4069 : freq(30)=146.832 : freq(40)=261.626
freq(41)=277.183 : freq(51)=493.883 : freq(61)=880.000 : freq(71)=1567.98
freq(42)=293.665 : freq(52)=523.251 : freq(62)=932.328 : freq(72)=1661.22
freq(43)=311.127 : freq(53)=554.365 : freq(63)=987.767 : freq(73)=1760.00
freq(44)=329.628 : freq(54)=587.330 : freq(64)=1046.50 : freq(74)=1864.66
freq(45)=349.228 : freq(55)=622.254 : freq(65)=1108.73 : freq(75)=1975.53
freq(46)=369.994 : freq(56)=659.255 : freq(66)=1174.66 : freq(76)=2093.00
freq(47)=391.995 : freq(57)=698.456 : freq(67)=1244.51 : freq(77)=2217.46
freq(48)=415.305 : freq(58)=739.989 : freq(68)=1318.51 : freq(78)=2349.32
freq(49)=440.000 : freq(59)=783.991 : freq(69)=1396.91 : freq(79)=2489.02
freq(50)=466.164 : freq(60)=830.609 : freq(70)=1479.98 : freq(80)=2637.02
freq(81)=2793.83
freq(82)=2959.96
freq(83)=3135.96
freq(84)=3322.44
freq(85)=3520.00
freq(86)=3729.31
freq(87)=3951.07
freq(88)=4186.01
dim ta$(88)
ta$(28)="q"
ta$(29)="2"
ta$(30)="w"
ta$(31)="3"
ta$(32)="e"
ta$(33)="r"
ta$(34)="5"
ta$(35)="t"
ta$(36)="6"
if layout$="DE" then ta$(37)="z" else ta$(37)="y"
ta$(38)="7"
ta$(39)="u"
ta$(40)="i"
ta$(41)="9"
ta$(42)="o"
ta$(43)="0"
ta$(44)="p"
do
 keys=keydown(0)
 notes=keys
 for i = 1 To 4 : k(i) = keydown(i) : next i
 if keys=0 then play stop
 for i=1 to keys
   handle_keypress(i)
 next i
 apply_restrictions()
 update_display()
 play_notes()
loop
sub handle_keypress(i)
 local j, kk$
 kk$=chr$(k(i))
 if kk$=chr$(27) then end ' we.end_program()
 ' Check for keys corresponding to musical notes
 for j=28 to 44
   if kk$=ta$(j) then tnr(i)=j : Exit Sub
 next j
 select case kk$
   ' Channel Oktave up and down
   case chr$(145) : okt(1)=okt(1)-12 ' F1
   case chr$(146) : okt(1)=okt(1)+12 ' F2
   case chr$(147) : okt(2)=okt(2)-12 ' F3
   case chr$(148) : okt(2)=okt(2)+12 ' F4
   case chr$(149) : okt(3)=okt(3)-12 ' F5
   case chr$(150) : okt(3)=okt(3)+12 ' F6
   case chr$(151) : okt(4)=okt(4)-12 ' F7
   case chr$(152) : okt(4)=okt(4)+12 ' F8
   ' All four Channels Oktave up and down
   case chr$(153) : for j=1 to 4 : okt(j)=okt(j)-12 : next j ' F9
   case chr$(154) : for j=1 to 4 : okt(j)=okt(j)+12 : next j ' F10
   ' Reset Tuning + Reset Oktaves
   case chr$(155) : for j=1 to 4 : okt(j)=0 : next j ' F11
   case chr$(156) : for j=1 to 4 : tune(j)=0 : next j ' F12
   ' Sound changes 1-4
   case "a"      : s(1)=s(1)+1
   ' If "y" or "z" corresponds to a musical note key then this sub will already have exited.
   case "y", "z" : s(1)=s(1)-1
   case "s"      : s(2)=s(2)+1
   case "x"      : s(2)=s(2)-1
   case "d"      : s(3)=s(3)+1
   case "c"      : s(3)=s(3)-1
   case "f"      : s(4)=s(4)+1
   case "v"      : s(4)=s(4)-1
   ' Detune channels 1-4
   case "g" : tune(1)=tune(1)+0.1
   case "b" : tune(1)=tune(1)-0.1
   case "h" : tune(2)=tune(2)+0.1
   case "n" : tune(2)=tune(2)-0.1
   case "j" : tune(3)=tune(3)+0.1
   case "m" : tune(3)=tune(3)-0.1
   case "k" : tune(4)=tune(4)+0.1
   case "," : tune(4)=tune(4)-0.1
   case else : exit sub
 end select
 notes=notes-1
 pause 100
end sub
sub apply_restrictions()
 local i
 ' Restrict ocatave values.
 for i = 1 to 4
   if okt(i) > 48 then okt(i) = 48
   if okt(i) < -24 then okt(i) = -24
 next i
 ' Restrict sound values.
 ' Only sounds 1 & 2 are useful, 3 and 4 are noise.
 for i = 1 to 4
   if s(i) <= 1 then s(i)=1 else s(i)=2
 next i
 ' Restrict frequency.
 for i = 1 to 4
   if okt(i)=48 and tnr(i) > 40 then tnr(i)=40
 next i
end sub
sub update_display()
 local i
 font 2
 color rgb(rnd()*255,rnd()*255,rnd()*255)
 print @(12,1) "* * * * * * * * * Mr. Polysynth by TweakerRay * * * * * * * * *"
 color rgb(0,255,0)
 print @(10,100) "Keydown   :" format$(keys, "%4g") format$(notes, "%4g")
 print @(10,120) "Frequency :";
 for i = 1 To 4 : print format$(freq(tnr(i)), "%10g"); : next i : print
 print @(10,160) "Tuning    :";
 for i = 1 to 4 : print format$(tune(i), "%4g"); : next i : print
 print @(10,180) "Oktave    :";
 for i = 1 to 4 : print format$(okt(i), "%4g"); : next i : print
 print @(10,200) "Key num   :";
 for i = 1 to 4 : print format$(tnr(i)+okt(i), "%4g"); : next i : print
 print @(10,220) "Sound     :";
 for i = 1 To 4 : print format$(s(i), "%4g"); : next i : print
 print @(10,240) "Layout    :  ";layout$
 font 1
 print @(10,320) "More music at http://tweakerray.bandcamp,com"
 print @(10,340) "And follow at http://www.youtube.com/tweakerray"
end sub
sub play_notes()
 local i
 for i=1 to notes
   if s(i)=1 then
     play sound 1,B,Q,freq(tnr(i)+okt(i))+tune(i),volume
   elseif s(i)=2 then
     play sound 1,B,S,freq(tnr(i)+okt(i))+tune(i),volume
   endif
 next i
end sub
Whilst I've been careful, as a non-musician I can't be certain that I haven't broken something.
I think there are two issues that were present in the original and which are duplicated in my code:
1) I'm not sure that keydown() correctly picks up multiple key presses. This may just be an issue with cheap USB keyboards, or it may be a general issue. I have raised the problem in the firmware RC1 thread.
2) If multiple note are being played simultaneously or the user is mixing non-note keys with note keys then I'm not convinced that the correct notes are being played on the correct channels.
Best regards,
elk1984
Posted: 12:55pm 20 Oct 2020
  thwill said  1) I'm not sure that keydown() correctly picks up multiple key presses. This may just be an issue with cheap USB keyboards, or it may be a general issue. I have raised the problem in the firmware RC1 thread.
From what I've read in the manual it should do, although I don't think it would work over TeraTerm or similar.
TweakerRay
Posted: 12:57pm 20 Oct 2020
Hi Tom, I‘m already on that problem.
I think i need to do a whole different approach for that. The soundchange you asked before works fine at my end the sine is just more silent than the square... i guess i have to do a more different keypress check... since i only check one key... this does work if you play one after another but not 4 keys at once... so i will try to work on this and solve the problem. Since I am still learning the code which i started has its flaws... i know but it works to the most extend - i will change the key checking...
Posted: 01:09pm 20 Oct 2020
No, keydown() doesn't work over serial, only for an attached USB keyboard.
I agree with your reading of the manual, I am strongly suspecting this may be to do with having a cheap USB keyboard, perhaps certain key combinations cannot be uniquely decoded or something ... I am not a hardware guy, but recall reading about something similar with some keyboard in the past.
Posted: 01:11pm 20 Oct 2020
  TweakerRay said  Hi Tom, I‘m already on that problem.
Thanks TR,
I agree regarding sine vs. square, when I changed the octave I could hear the sine wave sound.
I suggest you check-out my version of the code, because provided I haven't borked anything I think you will find it a lot "cleaner", YMMV.
Posted: 01:13pm 20 Oct 2020
... at the moment I'm inclined to think it is "good enough" and as soon as I've finished smoke testing the rest of the "Welcome Tape" I will release it as is. We can always add a Mr. Polysynth v2 in a later release. Do you agree?
TweakerRay
Posted: 02:23pm 20 Oct 2020
Hi ! I tried my best to change the keyaccess...
I also have the thought that the usb keymoard sometimes work and sometimes have problems with the keycheck...
This is what I came up with...
I think this is okay to demonstrate the "soundabilitys" of the cmm2 with the internal sounds...
Mr-Polysynth.zip
So Feel free to check this version... maybe it solved the problem ?
Edited 2020-10-21 00:24 by TweakerRay
Posted: 03:17pm 20 Oct 2020
Hi TR,
I"m in a quandary as I can't see how your changes improve the situation and it takes me back to square one in terms of tidying the code up for the Welcome Tape. Could you please look at the version I included above, if you are not happy then perhaps I would be best to leave Mr. Polysynth out this time?
In my musical ignorance I suspect what is required is a more advanced algorithm so that if A ... G are notes then:
- Press key for A then start playing A on channel 1.
- Continue to hold A and press B then play A on 1 and B on 2.
- Continue to hold A and B and press C then play A on 1, B on 2 and C on 3.
- Continue to hold A and C but release B then play A on 1, nothing on 2 and C on 3.
- Continue to hold C but release A then play nothing on 1, nothing on 2 and C on 3.
Is that the desired behaviour?
Edited 2020-10-21 01:18 by thwill
TweakerRay
Posted: 03:35pm 20 Oct 2020
Hi Tom, your code reseted my CMM2 while playing...
it also did not play 2 notes at the same time...
Then it crashed with
"Error System fault - possible caus
Incorrect use of POKE
faulty CSUB
Reserved words used as varibles
Firmware problem"
So I think if you want to use my last version I posted - I am fine with that.
I don't think your other version works better...
If you don't want to use it then leave it out... its your welcome tape...
What I tried to archiev was that you can press more than 1 key and each of the keys will have a note...
Problem with keydown is that if you lose one key of 4 pressed ones the last key switches over and such strange things... so the keypresses are not first press gets first note and so on... if you change your fingers on the keyboard the keys also switch... It's rather hard to describe...It works on my end here with a few hickups but better than the crashed version....
And I am sure some other people could programm it much better... I am a musician... not a professional coder - I do this for fun. So it is what it is... a not perfect but useable programm... otherwise just use Mr. Monosynth...
with just one key ?
Much easier... but more boring.
Mr-Monosynth.zip
Edited 2020-10-21 01:39 by TweakerRay
Posted: 04:02pm 20 Oct 2020
  thwill said  I am strongly suspecting this may be to do with having a cheap USB keyboard, perhaps certain key combinations cannot be uniquely decoded or something ... I am not a hardware guy, but recall reading about something similar with some keyboard in the past.
It's probably this: http://xahlee.info/kbd/keyboard_n-key_rollover_key_ghosting.html.
So that will place a hardware limit on the multi-key capabilities of Mr. Polysynth.
TweakerRay
Posted: 04:10pm 20 Oct 2020
WT.... actual... wow... I did not know about ghosting keyboards... I just tested this on my office keyboard and if I press (left shift)+(right shift) + X - I get no key...
If i do that on a different key it works... just not on the X...
Thats crazy...
Yeah I guess that is a very big limitation here in the hardware then ?
Maybe use my Game Heartattack instead ? ;-) It also supports the WII Classic now...
and has basic soundeffects and a mp3 playback at start ;-)
Hi TR,
Not sure why it crashes, I will have to test again, and I think I know how to fix some of the strange stuff you reported with multi-key presses, though hardware limitations may mean it can never be reliable for simultaneous key presses on some keyboards.
  Quote  And I am sure some other people could programm it much better... I am a musician... not a professional coder - I do this for fun. So it is what it is... a not perfect but useable programm..
Yes, and your programming is much better than my music.
It's just an unfortunate case here where my professional standards and the fact that I have ultimate responsibility for the "Welcome Tape" means I feel obliged to "tidy up" some of the code that is included - this always had the potential to be awkward when I started this project and is no reflection on you.
Thank you for your continuing contributions,
Posted: 04:32pm 20 Oct 2020
  TweakerRay said  Yeah I guess that is a very big limitation here in the hardware then ?
It looks that way, I may just add a warning about use of more than two simultaneous keys. People with more expensive USB keyboards may be able to use more.
  Quote  Maybe use my Game Heartattack instead ? ;-) It also supports the WII Classic now... and has basic soundeffects and a mp3 playback at start ;-)
Thanks for the offer, and maybe in a later version of the "Welcome Tape", but I don't want to start juggling new content so late in the release cycle for v0.5. I'm going to try and fix up "Mr. Polysynth" as well as I can (I want to include it because I feel it fills an important niche in the Welcome Tape's inventory) and then call it done ... once I've smoke tested everything with Peter's latest experimental firmware.
Best regards,
Edited 2020-10-21 02:33 by thwill
