Local Time 01:22 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic - Odd behaviour OR I've lost the plot
Nimue
Posted: 01:40pm 22 Sep 2020
Away from the CMM2 today and coding a class via MMBasic (DOS).
Created a function to convert a decimal to a binary (8 bit) number.   The function works fine when called individually -- binary(10) for example.  But when I wrap the function in a For/Next loop -- say I want to print all the binary from a to b -- it fails, with some odd behaviour.
Happy to acknowledge the issue is probably my code -- but after dropping this into class and testing it --- no idea why.
Any insight greatly recieved:
Function binary(x) As string
   'astr$ assembles the binary representation, in reverse
   Local astr$= Str$(x Mod 2) ' intial value
   Local rev$=""  'define the reversed string
   Local pad = 0  'the padding to make up to 8 bits
       If x Mod 2 = 1 Then  ' ie if there is a remainder
           x = x \ 2  'divide and round down
       Else
           x = x / 2  ' actual division
       End If
       astr$ = astr$ + Str$(x Mod 2)  ' assemble a string of the bits
   Loop While x <> 0
   pad=8-Len(astr$)   ' pad it out to 8 bits
   For n = 1 To pad
       astr$=astr$+"0"
   Next n
   For i = 8 To 1 Step -1
       rev$=rev$+Mid$(astr$,i,1)  ' reverse the string so it reads left to right
   Next i
   binary$=(rev$)  'dump rev$ into binary$ so that the function returns it
End Function
''Test the function
Print "Binary of 10 = " binary(10)  'test the function  - should produce 00001010  (ie 2^3 + 2^1 = 8 + 2 = 10)
Print "Binary of 128 = " binary(128) 'test - should produce 10000000
x = 11
Print "Binary of " x " = " binary(x)  ' passing x as a variable produces the right answer
''' works as expected until here...........
'' but when I wrap the function in a loop, all hell breaks lose.....
'' uncomment for fun
Print ""
For x = 8 To 16   'arbitary range to convert from decimal to binary
  'Print "Binary of " x " = " binary(x)    '' if you uncomment this and observe ????
  Print x    '' if you leave the above line commented, but uncomment this >> loop clearly working
Next x
Posted: 01:44pm 22 Sep 2020
I had the briefest of looks, but:
Variables are passed by reference, so in your code a call to binary(x) actually changes the value of x in the caller.
Posted: 01:45pm 22 Sep 2020
Variables are passed by reference in MMBasic. Take a local copy in the function and only change the copy
Nimue
Posted: 01:46pm 22 Sep 2020
  thwill said  I had the briefest of looks, but:
OK - get that.
So how do I programmatically call the function inside a loop ?
Sorry if I'm being dense.
Nim
Nimue
  matherp said  Variables are passed by reference in MMBasic. Take a local copy in the function and only change the copy
Got it -- I think.
Off for a play.. (ie serious tweaking)
Many thanks
Nim
Nimue
Posted: 01:51pm 22 Sep 2020
Solved....
Changing references to x in the function to "num" and defining "num" as "Local num = x" solved it.
Thank you!!!
Nim
Posted: 04:08pm 22 Sep 2020
Evening Nim
probably missing something - is the idea of the above code to teach *how* to do this or to end up with a binary representation of you number
Don't want to go down the Bin$(x,8) route without giving you due credit.
h
Nimue
Posted: 07:02pm 22 Sep 2020
  CaptainBoing said  Evening Nim
h
Good question.
I am teaching a group of students using the CMM2.  We are making a reusable library of "functions" - so to answer your Q - its about teaching how to do this, not actually converting from decimal to binary.  My example was more about the behaviour of the code, which turned out to be about passing by reference not value (which I sorted now).
As an extension, they are trying to figure out how to convert from any base (including negative bases) into any other base.  As in baseconv(15,2,3)  --> in this case -- convert 15 in base 2 to 15 in base 3 --> needless to say they are no where near this level of sophistication yet.  Some interesting math when you use negative bases.
Nim
Nimue
Posted: 07:06pm 22 Sep 2020
Nim
That said, I was unaware Bin$(x,8) existed --- at the risk of starting another forum meltdown, I tend to veer towards "big P" as my goto code --- that was until I discovered the CMM2.
Nim
Posted: 10:50pm 22 Sep 2020
Just to add more confusion to the mix.
Normally MMBasic complains if you define a variable with the same name but different type.
You can do this within a sub or function because it is local.
But when it comes to passing byref, things can get interesting.
 OPTION EXPLICIT
 DIM INTEGER s = 1245
 DIM INTEGER k = 1245
 PRINT "Same 'name' but different types"
 PRINT mytest(s)
 PRINT s
 PRINT
 PRINT "Same 'name' and same types = byref"
 s = 1245
 PRINT mytest2(s)
 PRINT s
   PRINT
 PRINT "Different 'name' and same types = byref"
 k = 1245
 PRINT mytest2(k)
 PRINT k
FUNCTION mytest(s AS FLOAT)
 s = s/2
 mytest = s
END FUNCTION
FUNCTION mytest2(s AS INTEGER)
 s = s/2
 mytest2 = s
END FUNCTION
It will catch you out if you are not using OPTION DEFAULT NONE and end up with floats by default then declare an INTEGER.
capsikin
Posted: 12:44am 23 Sep 2020
I didn't know you could refer to a string function called binary as binary$ (when you set its return value). When I've done that sort of thing with variables it gave an error, and it seems clearer to either always use or always omit the $.
Posted: 01:33pm 24 Sep 2020
A thought in passing:
      Else
      End If
Can probably just be
      x = x \ 2
Nimue
Posted: 02:30pm 24 Sep 2020
  JohnS said  A thought in passing:
      Else
      End If
      x = x \ 2
Nice stop -- to be fair, I was more focused on be overly explicit with the kiddos, but also in fairness, missed that one.
Nim
Posted: 02:38pm 24 Sep 2020
Might be interesting to see if any of the kids spot it...
Womble
Posted: 03:02pm 24 Sep 2020
  JohnS said  Might be interesting to see if any of the kids spot it...
Thats evil John
I didn't until I thought about it and checked the operator list in the manual
Nimue
Posted: 03:17pm 24 Sep 2020
Thats evil John
/ vs \ is really quite an interesting teaching point.
Many learners use them interchangeably when "doing math" -- ie
13 / 3 =    compared with 13 \ 3 = many teachers don't pick up the difference as many don't realise there is symbolically quite a difference.
One lovely thing of the CMM2 it that it give me an excuse to teach this stuff....
Nim
Posted: 08:55pm 24 Sep 2020
Nim
Try adding INT FIX and CINT into the mix.
Integer division is not the same as INT for negative numbers
\ rounds towards zero, not down.
DIM FLOAT x
FOR x = -5  TO 5
div x
NEXT x
END
SUB div(x)
PRINT
PRINT "x         ";x
PRINT "x/2       ";x/2
PRINT "x\2       ";x\2
PRINT "fix(x/2)  ";FIX(x/2)
PRINT "int(x/2)  ";INT(x/2)
PRINT "cint(x/2) ";CINT(x/2)
END SUB
Posted: 11:22pm 24 Sep 2020
This is a better example of the differences (and pitfalls)
DIM FLOAT n,k
DIM INTEGER m
PRINT "N   INT(N) CINT(N) FIX(N)  n\1  k\2   m"
FOR n = -3 TO 3 STEP 0.25
m = n ' assign a float to an integer
k = n * 2
PRINT STR$(n,2,2),,INT(n),,CINT(n),,FIX(n),,n\1,,k\2,,m
NEXT n
-3.00 -3 -3 -3 -3 -3 -3
-2.75 -3 -3 -2 -3 -3 -3
-2.50 -3 -3 -2 -3 -2 -3
-2.25 -3 -2 -2 -2 -2 -2
-2.00 -2 -2 -2 -2 -2 -2
-1.75 -2 -2 -1 -2 -2 -2
-1.50 -2 -2 -1 -2 -1 -2
-1.25 -2 -1 -1 -1 -1 -1
-1.00 -1 -1 -1 -1 -1 -1
-0.75 -1 -1 0 -1 -1 -1
-0.50 -1 -1 0 -1 0 -1
-0.25 -1 0 0 0 0 0
0.00 0 0 0 0 0 0
0.25 0 0 0 0 0 0
0.50 0 1 0 1 0 1
0.75 0 1 0 1 1 1
1.00 1 1 1 1 1 1
1.25 1 1 1 1 1 1
1.50 1 2 1 2 1 2
1.75 1 2 1 2 2 2
2.00 2 2 2 2 2 2
2.25 2 2 2 2 2 2
2.50 2 3 2 3 2 3
2.75 2 3 2 3 3 3
3.00 3 3 3 3 3 3
It aligns better on screen.
Between the floating point rounding and different methods, life gets 'interesting'
