Local Time 02:31 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Saving to Library
PhilTilson
Posted: 04:25pm 21 Sep 2020
Hi -
Couldn't find a 'search' facility on the forum - did I miss it?
I have a number of routines and four fonts stored in the Library (MM+) and, very occasionally, I need to add something to one of the fonts which shows graphic characters.
Is there any way I can do this without deleting the entire library and reloading all the routines and fonts again?
Alternatively, if I have, say, Font8 stored and modify the original, then enter LIBRARY SAVE on the Font8 listing, will this 1) overwrite the original, 2) add a new version of Font8, disabling the original or 3) try to add another Font8 thus screwing up the library?!
I am sure there must be a good technical reason why there is no selective DELETE on the library but, if there isn't, any chance it could be included in a future release?
Cheers.
NPHighview
Posted: 04:28pm 21 Sep 2020
Hi, Phil - The Search  function is the second item down under LOG OUT in the upper left corner of the forum page.  You can search for Any or All words, just not exact phrase.
- Steve (NPHighview) Johnson
Posted: 04:49pm 21 Sep 2020
Regarding "Search", you can also use google, which sometimes finds things you can't otherwise find:
"searchterm" site:thebeackshed.com
PhilTilson
Posted: 05:53pm 21 Sep 2020
Doh!
I was looking for a little text box with a magnifying glass.  I'm expected to read real words now?
