Local Time 02:30 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CM2:  My programs some of which are WIP
bar1010
Posted: 06:52am 20 Sep 2020
See attached zip file for my programs some of which are Work in Progress.
BAR_Programs.zip
CircuitGizmos
Posted: 04:39pm 20 Sep 2020
Fantastic!
Decoy
Posted: 05:23pm 20 Sep 2020
Does CM2 = CMM2?
elk1984
Posted: 06:04pm 20 Sep 2020
  bar1010 said  See attached zip file for my programs some of which are Work in Progress.
BAR_Programs.zip
Absolutely fantastic.  May I use code from font convert.bas (with accreditation) in the font editor Capsikin and I are working on?
bar1010
Posted: 07:49pm 20 Sep 2020
BAR_Programs.zip
Yes.  You may use any or all of everything that I post, modify it, post it here or elsewhere.  Created the dozens of programs that posted in nine days.  The font conversion is a work in progress that was really just meant to convert my specific case, but it could be modified to handle more cases.
elk1984
Posted: 08:07pm 20 Sep 2020
  bar1010 said
BAR_Programs.zip
Thank you.  Judging by your posts today, that's a very prolific 9 days   I'm looking forward to more of your work.
capsikin
Posted: 05:35am 22 Sep 2020
I noticed a comment in the font convert program that incomplete:
'8,12,32,39 in input file, so we have FF818989 89898989 898981FF
The bytes within each word are then reversed (not sure if that's the best explanation), so define font.fnt has:
898981FF 89898989 FF818989
I really like all the comments though, to explain the format.
bar1010
Posted: 06:43am 22 Sep 2020
  capsikin said  I noticed a comment in the font convert program that incomplete:
Yes, I thought that was the way it was going to function initially, but then realized they were reversed, but did not go back to modify the notes on what had originally thought.
bar1010
Posted: 06:45am 22 Sep 2020
