Forum Index : Microcontroller and PC projects : CM2: Mode for 1920x1080 resolution?
| bar1010 Senior Member Joined: 10/08/2020 Location: United StatesPosts: 197 |
Are there any plans to create a mode with 1920x1080 (1080p) resolution? |
Can the hardware do it? Hint: read the CPU datasheet. If the CPU can't then no. If yes, can the video hardware? (Overall I reckon NO. You want a different device.) John Edited 2020-09-19 08:33 by JohnS |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12088 |
Have a read |
The short answer is sorry but it cannot be done. Geoff Geoff Graham - http://geoffg.net |
