Local Time 01:22 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: xdel - recursive delete
epsilon
Posted: 01:07pm 18 Sep 2020
Hi again,
The mac/max archiving tools I posted earlier today can quickly leave you with a bunch of unnecessary files and directories on your filesystem. Deleting these one by one using KILL and RMDIR gets old just as quickly. The attached tool, xdel.bas, allows you to easily, recursively remove a directory and all its contents.
Details in the README below. Comments are welcome.
Cheers,
Epsilon.
xdel.zip
xdel recursive delete for Color Maximite2 by Epsilon
Version 0.1
xdel.bas allows you to recursively delete a directory and all its contents.
xdel.bas also lets you delete files in the current directory matching a filespec. See example below.
Example 1: Recursively deleting directory
> list files
A:/
  <DIR>  bak
  <DIR>  psgdemo
14:24 18-09-2020       3042  xdel.bas
3 directories, 12 files
> *xdel psgdemo
Recursive Delete 0.1 by Epsilon
Delete dir(s) psgdemo
Are you sure? (Y/N)? y
 Processing dir psgdemo
 Removing file .gitattributes
 Removing file psgdemo.bas
 Removing file psgmini.inc
 Removing file README.md
   Processing dir .git
     Processing dir logs
     Processing dir objects
       Processing dir 91
       Processing dir 9f
Done.
> list files
A:/
  <DIR>  bak
2 directories, 12 files
Example 2: Deleting files using fspec
> list files
A:/
13:59 18-09-2020          23  test1.bas
13:59 18-09-2020          23  test2.bas
> *xdel test*
Delete file(s) test*
Removing test1.bas
Removing test2.bas
Done.
> list files
A:/
Epsilon CMM2 projects
twofingers
Posted: 12:42pm 19 Sep 2020
Hi epsilon,
your Xdel is a very useful tool, I like it.
Thanks!
But the user interface is kind of improvable, as you certainly know.
Maybe your file tools can be combined with the FileBox?
Kind regards
Michael
PS. I am a little disappointed with the low level of feedback. I think it's important for newbies.
epsilon
Posted: 09:29am 20 Sep 2020
Hello Michael,
The interface is intended to be a very simple CLI. For more UI behavior I think it's a good idea to integrate into FileBox.
If you think the CLI needs improvement, suggestions are welcome :-)
Cheers,
Epsilon.
epsilon
Posted: 11:28am 28 Sep 2020
I put xdel on GitHub:
https://github.com/epsilon537/xdel
and I linked it in at Fruit Of the Shed:
http://fruitoftheshed.com/Colour%20MaxiMite%202%20(CMM2).Example-games-and-other-programs.ashx?NoRedirect=1#Utilities_8&NS=Colour%20MaxiMite%202%20(CMM2)
Cheers,
Epsilon.
